0-60
12-05-2011, 04:30 PM
Post: #31
0-60
The standard car when new did 0-60 in 8.6 seconds and the quarter mile
in 16.4 seconds at 83 mph.
http://retrorides.proboards.com/index.cg...read=49359
12-05-2011, 05:10 PM
Post: #32
0-60
totta Crolla Wrote:The standard car when new did 0-60 in 8.6 seconds and the quarter mile
Just the reason why 7.3 sound insane to me, if only pistons and ECU is changed.
It seems to me that that time would be great even for 180+ hp/fully striped AE86 with 4AGE 16V.
12-05-2011, 05:29 PM
Post: #33
0-60
You need around 150hp for 14.9 quarter mile AE86.
An increase of 30hp over stock is very significant.
12-05-2011, 05:45 PM
Post: #34
0-60
Quarter mile calculator seems to think it is closer to 170hp with a weight of 1100 kg for 14.9-15 seconds
12-05-2011, 08:18 PM
Post: #35
0-60
No need calculators for AE86, we all know pretty much enough.
150hp and low weight car (drag spec) seems OK for 15 sec mark.
But it's hard to imagine stock 4AGE (expect pistons) that can achive 150hp.
12-11-2011, 08:46 AM
Post: #36
0-60
Road & Track tested the 1985 Corolla GTS and achieved...
1/4 mile @ 18.60 seconds and 79.5 mph.
0-60 mph @ 10.5 seconds, citing axle tramp as being a limiting factor.
Car weight as tested @ 2640 lbs (1199 kg).
The AE86 was never a hp monster, but could hold its own on the road
due to good brakes, factory LSD and decent handling. In Japan it was
getting whupped regularly by the Honda CRX 1600, and a little later by
the Suzuki Swift GTI 1300. Power to weight is where it's at Smile
Cheers... jondee86
12-11-2011, 12:32 PM
Post: #37
0-60
1.2tons? WTF?! Huh
AE86 GT - SR20DET BlackTop //// Trackday beater
Citroen C4 Coupe VTR - 1.6HDi //// Streetcar
12-11-2011, 12:47 PM
Post: #38
0-60
Curb weight stated @ 1112 kg, so I guess the weight as tested included
for the driver and a bit of test gear. My car (UK spec) weighed 1060 kg
without driver, last time I had it on the scales.
Cheers... jondee86
12-11-2011, 05:47 PM
Post: #39
0-60
10sec is too much.
Descent AE86 can go 8,5-9sec easily with ~ 1100kg, car with two passengers.
12-11-2011, 08:35 PM
Post: #40
0-60
Uzelac Wrote:
BOOMEX Wrote:0-100km/h @ 7.29
1/4 mil @ 14.94
AE86 Zenky with a 4.3
Bleutop with TRD pistons and AE92 Tvis ECU Wink
175/70/13 tires.
Stock cams ?!
Yes the cams are the stock bleutop ones. (240° / 7.5mm lift)
The crank and rods were a litel lightened and rebalanced.
The head is worked too.
It's got a 4in1 Iresa header and a home made 2.244 inch (Ø57mm) over axel cat back
Fiber glass boot lid with stock window
Sound deader is all removed the cas if fully re-welded with some reinforcement
Full interior heater ect.. except the carpet.
From a 2nd gear pull i'm with a 170hp civic from 60km/h to 180km/h.
Wink
SR Team
BURN THE RUBER NOT YOUR SOUL!
