10.8:1, 264/256° Bigport
06-05-2017, 09:48 AM
I have some engine issues and I'm going back to a bigport in my Carina. The engine is rebuilt with smallport pistons and I'm going to use a 0.8mm TRD headgasket. This should get the compression up to 10.8:1 right?
The head is fitted with 256/256 HKS cams (8.1 lift i think). I might swap the intake for a 264° cam.
It will run with a redtop ECU and intake manifold.
Will a bigport work at that high compression? Would you suggest adjustable camgears?
Give me your input and experience!
Skickat från min ONEPLUS A3003 via Tapatalk
06-06-2017, 08:24 AM
I haven't run that particular combination of parts, but essentially it is no
different from putting a bigport head on a smallport block, and that has
been done many times. You end up with a high compression bigport that
will respond well to bigger cams.
Since you will be running it on a bigport ECU the fueling won't be far off. If
you have an O2 sensor plugged in, the ECU should be able to compensate
well enough for the modifications. Better still if you have an AFM setup.
And you will need to experiment with cam timing to get the best results
for you style of driving, so definitely a good idea to get some adjustable
cam pulleys.
Cheers... jondee86
PS: By redtop I take it that you are referring to the later TVIS engine and
not to the smallport engine ?
06-07-2017, 12:18 AM (This post was last modified: 06-07-2017 12:20 AM by oldeskewltoy.)
clear up "redtop" and we can better assist. (ECU AND manifold)
additionally... your Carina would be rwd... so using either "redtop" manifold may require some modifications as both "redtops" would be fwd.....
Dan -
06-10-2017, 09:54 PM
(06-07-2017 12:18 AM)oldeskewltoy Wrote:  clear up "redtop" and we can better assist. (ECU AND manifold)
Its a smallport ecu and intake. I've had a 4age in my carina for 2-3 years so the intake is already flipped. Everything is smallport (injectors and such) except for the block and head basically
Engine started today with 256/256° cams, but it knocks a bit..
Since bigports don't have a knock sensor I welded a nut to the block in the same positions that the smallport block has the sensor and put it there. I've had this engine in my car before, only difference was it had a regular head gasket. So I assume that the sensor works. Gonna try and adjust the distributor a bit more tomorrow..
06-12-2017, 09:57 AM
Can't hear any knocks anymore but there's a very noticable dip in power above 5000rpm.
I tried to tinker a bit with the knock sensor and the respons felt better for a while then it went back to a pretty sluggish state. I'm thinking the sensor or the connector is bad and the ECU is overcorrecting because of it?
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,576 04-20-2018 09:14 AM
  16v Bigport fuel problems Rascal21 1 4,809 07-04-2015 01:00 AM
Last Post: jondee86
  4A-GE: Bigport with smallport fuel injection nyberrg 7 11,555 06-13-2015 05:00 PM
Last Post: nyberrg
  4age smallport oil pump in bigport engine? ditn 2 8,271 12-06-2014 08:10 PM
Last Post: ditn
  4AGE 16v RWD Bigport Diagnostics Plug? Rascal21 2 7,733 11-15-2014 09:31 PM
