20 Valve Blacktop smoking after engine flush - why?
11-30-2022, 10:52 AM
Hi guys
My 20 valve blacktop is totally stock and never been opened before. I bought the car (2000 Corolla GT 6 speed) with 150 000 miles on it and I did not know what kind of oil was used for the longest time in it. VVT cam gear needed to be changed. I changed that and now she pulls so hard and feels so healthy! One of the first things I did was run Liqui Moly engine flush before running new synthetic 5W40 Liqui Moly oil. That flush probably did it's job really well since after this oil change, the rear main started leaking profusely and oil burn with smoke became apparent. I'm imagining the amount of sludge there was inside the engine :/ There was varnish on the cams and under the cam cover prior to this service.
Thoughts?
11-30-2022, 12:04 PM
Time for some new valve seals perhaps.
11-30-2022, 12:09 PM
(11-30-2022 12:04 PM)Ivan141 Wrote:  Time for some new valve seals perhaps.
I changed those to new Supertech seals from Battle Garage RS. I also changed the cam seals and VC gasket to new OEM ones.
  4A-GE valve shim disintegrated DaLanZhu 2 1,765 04-30-2025 12:54 PM
Last Post: DaLanZhu
  4AGE Valve Buckets Scored Steller Engineering 2 2,009 10-06-2023 05:34 PM
Last Post: Steller Engineering
  PWR light issue and no brake fluid after winter storage magpie 10 5,616 05-25-2023 08:09 AM
  HKS valve springs totta Crolla 3 3,655 05-25-2022 10:24 PM
Last Post: oldeskewltoy
  Exhaust has white smoke coming out and I dont know why... mister86 3 6,372 01-19-2020 12:06 AM
Last Post: Power_uP
