20V 4AGE idle droping time to time? why?
08-30-2010, 11:44 AM
I have a 20v blacktop in my 86 and the idle is droping to 550 from time to time which sucks as the car will cut out if i dont keep the rev up? oil pres is perfect as i build up revs..?
i read it could be a matter of cleaning out the ISCV and the throttle cable tightened anybody had this? |
08-30-2010, 02:26 PM
Also check your coolant levels.. throttle cable is unlikely to be the culprit if you have trouble @ idle.
11-09-2010, 03:05 PM
Is this a recent development or has it been there since the conversion?
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,281 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,201 |
Engine starts/revs but no idle | GenkiMotors | 17 | 6,767 |
Exhaust has white smoke coming out and I dont know why... | mister86 | 3 | 4,342 |
01-19-2020 12:06 AM Last Post: Power_uP |
exhaust odor/idle MOT issue | Ryo | 7 | 7,008 |
