20V shim micrometer
02-21-2017, 10:26 PM
20V shim micrometer
Fowler 1/2" caliper 52-230-000-0 • 0-1/2" micrometer by .001", Satin chrome finish. • Forged steel frame • Anvil and spindle hardened and precision ground with microlapped ends • Clear, crisp graduations on barrel and thimble. • Diameter of measuring faces: .197" • Flatness: .00003" • Parallelism: .00005" • Accuracy: .001" • Range: 0-1/2" • Includes case The diameter of the measuring faces of this caliper =.197", which = 5mm. So if you are doing valve adjustment on 20V head[s], you may want this tool to check shim thicknesses. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-19-2017, 07:18 PM
20V shim micrometer
works for me.... managed to get this clients 20V to the tighter side of the spec, then the looser side it had been.
Exhaust were .018"-.020", they are now much closer to the tight end with 7 between .015", and .016", and a single one @ .017" - because I didn't have another shim that was either .001", or .002" thicker then the one in there, and while a tiny bit looser, it is still .003" tighter then it was when it came to me. On the intake side - all the clearances are between .007 and .008, they ALL had been .011" Biggest problem I need to solve - a method to mark the shims so I don't have to constantly remeasure... also.... Need to get more shims... AND a 20V shim box Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-20-2017, 10:08 PM
20V shim micrometer
Need to get me one of these for when I get round to doing the 16v
12-21-2017, 01:11 AM
20V shim micrometer
Get yourself a sorting tray thingy, that seems to be an easy way of keeping track of the thickness. Bonus you can keep any spares in there too
AE86 ex-daily |
12-21-2017, 10:55 AM
(This post was last modified: 12-21-2017 11:05 AM by d3nso.)
20V shim micrometer
Bean is right get something like this:
12-21-2017, 11:33 AM
20V shim micrometer
Personally to mesure shim I use (something like) this:
When you have a lot of them to measure, it goes way faster than with a micrometer. |
12-21-2017, 05:58 PM
20V shim micrometer
(12-21-2017 11:33 AM)Project D Wrote: Personally to mesure shim I use (something like) this: very nice..... but currently outside my budget... I don't do enough 20V's YET....... as to a tray, or sorting for the 20V shims... I'm kinda in/at a dilemma point right now... not enough spare shims to actually begin a kit yet..... This is my 16V kit... and as you can see, due to machining tolerances... I have 16V shims down to a thousandth... there are about 500 shims in this kit. For these I use a dial caliper that measures in thousandths Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-22-2017, 12:23 AM
20V shim micrometer
(12-21-2017 05:58 PM)oldeskewltoy Wrote: very nice..... but currently outside my budget... I don't do enough 20V's YET.......Yes if you go for the Starrett in the picture it is expensive. But there are similar products who are affordable (That is why I added "something like") Exemple: Fowler Indicator and Stand Combo 52-580-109 -> ~$150 (If you already have a dial indicator, the stand alone is ~$80) Sure it is 3 or 4x the price of the micrometer, but it is not out of reach. |
Shim size for AM cams | kazi | 4 | 5,151 |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,084 |
09-15-2013 01:08 AM Last Post: jondee86 |
4A-GE Shim where to buy | megabob | 12 | 12,643 |
01-11-2012 12:57 AM Last Post: ZDoman |
Under shim bucket kit qustion | Jimmi The Kid | 13 | 16,096 |
07-08-2009 04:04 PM Last Post: Bean |
Shim overbucket ghetto | apardal | 4 | 4,982 |
10-14-2008 05:44 AM Last Post: F0Bman |
