264/256 vs 256/264
01-13-2010, 10:02 PM
264/256 vs 256/264
There is no "software" which does that. I use dyno2003 to simulate the numbers but there is more than just click this and click that....
01-13-2010, 11:13 PM
264/256 vs 256/264
Engine Analyzer can be used to really calculate power and its about near as 97% accurate.
Thing with power calculations is that you only roughly measure power. And power is useless without torque. If an engine performs like it should the torque won't be much off from the power and it will drive nicely. Running @ about 140 hp @ the wheels should make at least 150nm or else the car will feel slow like hell Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
01-13-2010, 11:50 PM
264/256 vs 256/264
but power & torque are related. So If you know power you know torque
01-14-2010, 12:21 AM
264/256 vs 256/264
did you keep lift the same all the time as well as the timing of the cams (overlap)?
most setups I've seen use a bigger intake and smaller exhaust duration. I'll crunch some numbers tomorrow if I can dig out the program and se what I can find AE86 ex-daily |
01-14-2010, 12:30 AM
264/256 vs 256/264
no. The 240-240 setup is with the standart lift. And the others are HKS so around 8.1mm. Overleap is around 111 for standart cams and 110 for the HKS ones.
But yeah Bean your Input would be very cool. |
01-14-2010, 01:01 AM
264/256 vs 256/264
please send me a file for your stock input and I'll go from there will save me a bit of time - especialy the induction part
Overlap is 18° on bigport but yeah 111° centerline AE86 ex-daily |
01-14-2010, 11:43 AM
264/256 vs 256/264
MartinS Wrote:but power & torque are related. So If you know power you know torqueWhat was the head cfm value for your calculations? (will put my files somewhere online, and post it when it's done) http://www.ae86.hu |
01-14-2010, 12:04 PM
264/256 vs 256/264
Put my calc files here:
http://www.ae86.hu/download/54/ http://www.ae86.hu |
01-26-2010, 01:38 PM
264/256 vs 256/264
272/272 with Wisecos and VEMS
full details here http://www.aeu86.org/viewtopic/tuned-4ag...highlight= http://www.skynet.ie/~eireae86 |
01-27-2010, 09:25 PM
264/256 vs 256/264
XJS Wrote:Put my calc files here:which software can i use to run these files? **COROLLA EE80 - 4AGE 124HP** |
10.8:1, 264/256° Bigport | nyberrg | 4 | 6,080 |
06-12-2017 09:57 AM Last Post: nyberrg |
HKS 264 8.35mm lift cam shaft....help needed! | lolali | 8 | 7,922 |
08-06-2009 09:01 PM Last Post: apardal |
272, 264 cam. | eowk_3456 | 3 | 4,343 |
08-05-2008 06:30 AM Last Post: F0Bman |
Settings for HKS 256 cams on stock engine | Bean | 7 | 7,820 |
03-16-2008 10:56 AM Last Post: Bean |
