3rd door support gas springs (stay) - worn out
08-27-2013, 03:55 PM
It is time to replace my old and worn 3rd door gas springs. Is there any replacement possibility from other vehicles? Any suggestions?
Fun is not the straight line!
08-28-2013, 09:29 AM
If the only problem with them is that they don't hold the hatch up (drops
on your head when you are getting something out of the back), then you
might be able to get them re-gassed. There are businesses that do that
by putting the whole strut into a steel tube, and pressurising the tube with
nitrogen. This forces gas into the strut past the seal, and two minutes later
you have a working strut Smile
Could be worth asking around... ?
Cheers... jondee86
08-28-2013, 10:22 AM
Thanks, Jondee86. I found "Stabilus SG230008" as a perfect replacement but shipping from US to EU is a killer. The problem with my struts is pressure + worn ball & sockets, so I was thinking to replace them with new pair of struts.
08-31-2013, 04:00 PM
I managed to fix the ball joint. I just replaced the old snap ring. The old one has been totally worn out and corroded. The compression is still acceptable so I think this is it for now Hurray!
09-01-2013, 03:20 PM
If it ever comes down to it, I don't know if anyone else here has tried these? http://www.ebay.co.uk/itm/2-X-TAILGATE-B...5d34f7cfcc
  Radiator & grill support panel (Levin) FanIsHere 5 2,111 11-14-2022 10:07 PM
  HKS valve springs totta Crolla 3 2,226 05-25-2022 10:24 PM
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 29,193 06-27-2018 11:15 PM
Last Post: Ryo
  Shifting from 4th to 3rd pack 7 6,322 04-27-2017 07:26 PM
Last Post: totta Crolla
  Springs from other vehicles?? FanIsHere 16 14,567 05-17-2016 09:12 AM
Last Post: FanIsHere
