4A-C Engines
07-17-2005, 07:29 PM
4A-C Engines
How many people here have a 4A-C powered AE86?
I've got a small annoying problem, Im not sure what it is exactly, when im driving and drop it into Neutral, ik usually get a "putt putt" noise. also when i rev the engine, its like Vroooooooooooooooomm putt putt. LOL
Whats causing this? is it the carburator?
Sniper
1986 Toyota Corolla SR5
1989 BMW 535i
1986 Volvo 740 GLE
07-18-2005, 09:43 AM
4A-C Engines
Check (replace) all little vacuum hoses :-)
Lets check something - when you drive in traffic and put on gas pedal, then fully depress is - are there some delay of RPM fade ?
07-18-2005, 06:59 PM
4A-C Engines
Where does the "putt putt" come from? The exhaust or the engine bay? Somewhere else?
Using: -98 Camry 3.0 V6
Abusing : -85 Corolla 2.0 GTi
07-18-2005, 07:43 PM
4A-C Engines
Yeah when i rev the engine, it hangs for a maybe a second then goes down, the "put putt" come from the engine but the sound comes out the tail pipe, its not the exhaust, its all new pipes
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
07-18-2005, 07:48 PM
4A-C Engines
I heard that this can be some ecological equipment. In order to prevent polutions - in described case. Look at your carburator - check vacuum hoses also, check ignition advance - but keep in mind that this may be normal behaviour in some cases.
07-18-2005, 08:01 PM
4A-C Engines
i had it also with my 4age but that was when the ignition was not correct.
07-18-2005, 10:23 PM
4A-C Engines
Jaimemirror is on the right track.. I've had a couple of AE82's with this engine and I know they have a little vacuum diaphragm called a "dashpot" on the carb.
Pop the hood and remove the air cleaner so you can see the carburettor. Then start the engine and rev it by turning the throttle directly on the carburettor instead of pushing the pedal. When you let the throttle go, watch as the dashpot moves up and "catches" the throttle on its way down.
As said, it is an emission control device that is supposed to make your emissions cleaner.
07-19-2005, 05:41 AM
4A-C Engines
If i understand correctly...is it normal? its not the engine or carb needing maintenence or needs to be replaced?
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
07-19-2005, 08:01 AM
4A-C Engines
SniperGT Wrote:If i understand correctly...is it normal? its not the engine or carb needing maintenence or needs to be replaced?
Yes, it can be normal. Just check hoses and ignition advance to be sure that everything is ok.
  Toyota Engines Gallery... alimonos 65 206,364 07-26-2013 11:08 PM
Last Post: montrueno
  What engines fit in AE86 (LEVIN) eScOvInHaS 8 13,099 01-19-2011 11:59 PM
Last Post: NoHachi
  Engines? Project_Panda 8 8,929 08-10-2006 02:16 PM
Last Post: NoHachi
  engines that fit in the ae86 rsx 4 6,253 07-27-2006 11:13 AM
Last Post: Max_Misawa
  4age (87-89) engines at Fensport dreja 11 13,414 01-30-2005 09:37 PM
Last Post: gon
