4AG 16V Low oil pressure at idle 10PSI guage autometer
05-31-2009, 10:07 AM
What kind of engine oil do you use?
The 4agze oil pump is the same in the smallport 4age and the ae101 20V 4age. ae111 blacktop pump is also the same by gears inside, but the cambelt tensioner is different. I think you should check your connecting rod bearings and oil pump (especially the pressure relief valve) If you have the original toyota oil cooler setup you should check the oil pressure relief valve inside aswell. |
Messages In This Thread |
4AG 16V Low oil pressure at idle 10PSI guage autometer - CHACAMAN - 05-31-2009, 12:16 AM
[] - ZDoman - 05-31-2009 10:07 AM
[] - corolla4agze - 05-31-2009, 10:17 AM
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,559 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,740 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,704 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,460 |
exhaust odor/idle MOT issue | Ryo | 7 | 7,532 |
