4AGE 16V Timing Issue
01-12-2012, 05:34 AM
Dear all, due to my 4A minor shaking during ideal. so check timing
with timing light and found out that it as 20deg. it high then i thought but the engine still shaking. i lower the timing but engine die after lower it. did any one can assist me on this issue. thanks. |
01-12-2012, 06:51 AM
This thread should help, http://www.aeu86.org/viewtopic/4age-igni...ght=timing
AE86 ex-daily |
01-13-2012, 02:41 AM
What's the compression????
The Ignition timing doesn't change by itself, it's either 10's of thousands of kilometers of wear for a very minor change or someone F'd with it. It will not change enough by itself to cause a rough idle in a short period of time, it takes years, not days weeks or months. You've got some other problem. So what! |
01-14-2012, 03:46 PM
look at bean banit´s link!
If that fails I´d have a look at compression. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
02-04-2012, 06:53 AM
thanks guy. i still try to figure how to solve this issue.
02-04-2012, 09:07 AM
what RPM is it idling at??
PWR light issue and no brake fluid after winter storage | magpie | 10 | 2,430 |
Fuel pump issue | DJexor | 11 | 4,885 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 20,431 |
Clutch Issue | Deaty | 8 | 4,126 |
04-09-2021 10:26 PM Last Post: Nakilad |
5th gear issue | r.ave | 1 | 2,494 |
03-14-2021 08:52 PM Last Post: Ivan141 |
