4AGE 16V crank weights
02-03-2013, 12:33 AM
Always intrested on this subject, and I just measured a 40mm bluetop crank and a 42mm redtop crank for comparision, which I thought is quiet intresting and worth sharing.
40mm crank 11,40kg
42mm crank 12,40kg
Quiet impressive to have 1kg less on the engine internals!
Fell free to add 20V weights if you got any Wink
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
02-03-2013, 08:00 AM
this is exactly the reason why I went with custom rods to suit the best of both worlds Wink
AE86 ex-daily
02-09-2013, 07:42 PM
Im using the 40mm crank with some H beam rods i sourced through Leadworth racing should be a cool setup when done , i knew the crank would be lighter but never knew by how much thanks Thumbs up!
02-09-2013, 08:52 PM
i've measured the OEM 10:1 pistons with OEM conrods last year, but i don't know it any more Banging head
what i do remember is that the lightest one was only 4 gramms lighter than the havviest one, that's pretty nice i think Thumbs up!
OEM flywheel weighs about 7,4 KG (200mm clutch)
'87 levin coupé
[Image: AEU86 AE86 - 4AGE 16V crank weights]
02-09-2013, 10:01 PM
PatrickAE86 Wrote:i've measured the OEM 10:1 pistons with OEM conrods last year, but i don't know it any more Banging head
lighter (over 20 grams ) still when you replace the original pins...
may not seem like a lot... but the pistons and pins, going up, going down, starting, stopping... the mass on each rod, piston and pin is far more substantial then a kilo in the crank which is only rotating and has no starting/stopping to deal with
not entirely true because of torsional loads on the rod journals... but the crank never has to start, and stop repeatedly thousands of times a minute
Dan -
02-09-2013, 10:08 PM
what was the weight of your custom pins Dan? I'll have to borrow some proper scales and weigh my JE ones and everything else I have. Will make a good resource for other and us.
AE86 ex-daily
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 20,749 05-01-2021 10:09 PM
  4AGE 16V engine overheat when at high speed chenfon 32 21,541 12-31-2020 06:39 AM
Last Post: chenfon
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 7,340 11-09-2020 10:51 AM
Last Post: totta Crolla
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 17,335 08-16-2018 01:36 AM
  crank 6 bolt flywheel DJexor 5 8,086 12-05-2016 08:21 AM
Last Post: d3nso
