4AGE 20V BT timing belt and tensioner
03-09-2012, 12:04 AM
I'm thinking about using the 16V timing belt tensioner on my 20V Blacktop.
I realized that the belt itself is different for the Blacktop, so I will have to use the original one. Is it possible to use the 16V tensioner, while still using the 20V BT oil pump? I don't have the engine with me at the moment so I can't really check it out. Thanks 86'LEVIN Track Project |
03-09-2012, 05:04 AM
You could use the 20V SILVERTOP tensioner or 16v one but I think you have to change the oil pump too...
They are pretty different and the blaktop pump doesn't have the threaded hole for the tensioner bearing. 16v / 20v silvertop: Blacktop: |
03-09-2012, 09:33 AM
4AGE 20V BT timing belt and tensioner | |||
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,456 |
Rear Seat Belt Question | sleepercivic | 5 | 9,942 |
06-29-2017 09:30 PM Last Post: banpei |
4agze timing | leon205gti | 11 | 13,608 |
04-07-2017 03:10 AM Last Post: jondee86 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,281 |
[Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 5,461 |
04-21-2014 02:41 PM Last Post: Homem Bomba |
