4AGE Silvertop torque setting
07-31-2009, 01:56 AM
Hi everyone
Can I use the blacktop engine torque setting on my silvertop? Such as Placing back te Connecting Rod Cap and etc? |
07-31-2009, 03:59 AM
Just checked now and both silver and blacktop torque settings are the same:
60Nm for the crank bearing caps 29Nm for the rods caps 9,5Nm for the rear retainer 45Nm for the knock sensor 14Nm for the water pump 75Nm for the flywheel 30Nm +90º + 90º for the head 17Nm for the cam caps Still have to cross references with the 16v but from what I remember its almost the same (only sure about the head and crank caps) ![]() |
07-31-2009, 06:12 AM
Many thanks for your help!!!
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 4,380 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 15,023 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,922 |
Torque settings | kazi | 4 | 8,395 |
03-28-2017 12:15 AM Last Post: kazi |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 6,482 |
