4AGE Silvertop torque setting
07-31-2009, 01:56 AM
Hi everyone
Can I use the blacktop engine torque setting on my silvertop? Such as Placing back te Connecting Rod Cap and etc?
07-31-2009, 03:59 AM
Just checked now and both silver and blacktop torque settings are the same:
60Nm for the crank bearing caps
29Nm for the rods caps
9,5Nm for the rear retainer
45Nm for the knock sensor
14Nm for the water pump
75Nm for the flywheel
30Nm +90º + 90º for the head
17Nm for the cam caps
Still have to cross references with the 16v but from what I remember its almost the same (only sure about the head and crank caps)
[Image: AEU86 AE86 - 4AGE Silvertop torque setting]
07-31-2009, 06:12 AM
Many thanks for your help!!!
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 1,982 05-26-2024 07:40 PM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,292 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  20v silvertop idle issue AlexFourTwenty 3 5,111 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Torque settings kazi 4 6,752 03-28-2017 12:15 AM
Last Post: kazi
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,815 02-20-2016 11:48 AM
