4AGZE - REBUILD AE86 NYC's "Black Prophet"
06-20-2009, 02:58 AM
[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."][Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."][Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."][Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."][Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
Im rebuilding my 101gze.....what happened to it you ask? i finished blowing the doors of a 350z on the highway.....3 car lengths you dont need alot hp to get around these new cars...lol...well when i got 5 mins from home it started to make noises ..clicking & clacking .. i was like oooooooh shyt she's dying lol....but i knew ...it needed a rebuild just needed an excuse to do it...... + $$$$$$$$$
im shooting for a good street able gze...i cant be wasting money ..blowing rears and constantly buying tires...lol -$
at least over 200whp i would like ......last dyno was 145whp psi unknown at that time... i did some work to it.... so i know i was pushing more hp....before it went.....im guessing 160-170whp? @ 10psi cracking 11 in the winter
MY 1986 Corolla GTS aka (Black Prophet ((The Hunter)) 13th Apostle....
theme song..........
YouTube - Ghostface Killah - Daytona 500
here is a vid:
YouTube - ULTIMATE AE86 & JDM RIDEZ SLIDESHOW
[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."] old pic
stuff i acquired so far
Greddy emanage
Cusco 14psi pulley
CX racing front mount
thinking of doing?
port & polish
256 cams + gears
3 angle valve job
what else you guys suggest?????
im open for suggestions..................
ok lets get to work............what i suggest before removing the motor...
1 buy tape & a marker for labeling plus a white paint marker for dark surfaces
2 remove f.bumper grill & headlights for easy access plus less of a chance of things getting damaged...
3 have a lot of space, good tools, & speedy dry cuz things are going to get messy!
well my friends & i started to take her apart.....to see what actually happen to her
1st problem we ran into was the wire harness & vacuum lines....gze's are spaghetti when it comes to that..............solution label everything!!!... we pulled out the entire main harness to make things easier for labeling .....i seen hoses and wires i never lay eyes on before............lol well some of that is the Greddy e manage, boost gauge & oil pressure...hopefully can achieve type of wire tuck
2nd problem we had was the engine didn't want to separate from the tranny but with a little finessing we got it separate...a whole 30min....stubborn......lol
and when started taking the clutch out...............damn! clutch dust all over the place
stick a fork in it........done!! work the clutch to the bone.....
well here is the motor.....and yes that is an MR-2 bracket & alternator bought new almost $400 from dealer....I originally had the jdm set up....power steering ac pump alt....but the bracket snap...and i couldn't source one...so i opt for the MR-2
will post more pics as i go on.............
UPDATED PICS::
08-02-2009, 08:55 AM
i sanded down the engine bay....getting ready for its new bay paint job
1[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
2[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
3[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
4[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
5[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
6[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
7[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
8[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
9[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
10[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
11[Image: AEU86 AE86 - 4AGZE - REBUILD AE86 NYC's ..."]
Reppin' the old skool....Drive Drift Dream
08-02-2009, 02:52 PM
looks like I am looking into a magazine lol. Good job on the car. If you want your 4agze to push around 200 hp you will need to do some serieus head rework and get a set of good cams.
Let me start with the basics. DON"T take high duration cams as a SC or turbo engine should not rev to high. Take high lift cams with a duration at a max of 272. (rather 264) and like 10mm lift with underbucket shims.
Then your engine can really start pushing it. you will have to toss away the standard ecu.
08-02-2009, 08:16 PM
i didnt see lifts over 8.1 for 256..im still using the stock springs...i spoke to hks and a few people and from what i was told that i didnt really need to change the springs with that duration?
this is list what i have & bought i for it
cusco 175mm pulley
cxr front mount intercooler
hks 256 in/ex 8.1 lift
hks cam gears
hks timing belt
new 20 over gze pistons 8:9
new federal crank bearings
new toyota oil pump
toyota complete rebuild kit
arp fly wheel bolts
arp head bolts
arp connecting rod bolts
Exedy stage II clutch
steal braided clutch line
AEM eugo wide band
new toyota water pump
koyo radiator
tomei fuel pressure regulator w/fuel line adaptor
trd engine mount
cusco tranny mount
cusco f/r anti sway bars
cusco f/r strut bars
greddy e manage
greddy tic cat back
greddy type s coilovers
greddy big brake kit 6 mini piston
greddy oil pressure gauge
greddy boost gauge
magnaflow catalytic
Dmax carbon fiber hood
13lbs drive shaft
the motor:
sent injectors to be cleaned and calibrated...now pushing 388cc
new fuel pump
new rear koyo axle bearing
ported & polished
port matched intake manifold
new valve seats
new over sized valves
crank,piston,connecting rod balancing
flywheel cut
ugraded the starter to a 1.6 kw
new toyota altenator
if there is anything that you guys suggest i should or get ....please let me know...
things that im thinking of getting
hks twin power dli
hks hydraulic upgrade kit
08-03-2009, 05:14 AM
any suggestions anyone??
08-03-2009, 08:03 AM
ae86driftmaster Wrote:any suggestions anyone??
Hey!
I have bad experiences with aftermarket bearings... I'd advise you to buy original toyota, or TRD ones!
None of the aftermarket bearings has size selection in the base (48/42) size. So you can't equalize the clearances.
The other things are seems to be good! You'll have a nice engine Cool
08-04-2009, 04:21 AM
i will look into that (Bearings)
anyone else could think of anything else mechanical wise? that will improve the car?
08-09-2009, 09:40 AM
08-09-2009, 12:46 PM
well you could have different cams. I am running 262 9mm lift and 256 8.5 mm lift. These are more aggressive in opening which should be perfect for a GZE.
Regarding your setup, I pretty lost it? Are you building a 20V SC or a 16v SC?
And take a trd or hks head gasket because the amount of pressure will go up with different cams and a SC.
Small tip: upgrade your rear brakes. You just fucked up your brake balance for front and back. Considering the amount of money you pumping in I assume you spot welded most of the chassis already? That should increase stiffness a lot
08-10-2009, 02:27 AM
im building ae101 4agze 16v
going for more reliable street tune 256 8.1 mm lift in/ex
the brakes im just going to add rear steal braided lines and get better quality pads/rotors...project mu im guessing
i have f/r strut braces...thinking of getting a underbody brace and cusco roll cage....that should be decent
i havent found any one yet that has the know how to do spot welding correctly
  Scottish Trueno rebuild - Nürburgring with pics! kazi 77 183,360 11-25-2018 11:42 PM
Last Post: kazi
  Patrick's rebuild topic PatrickAE86 13 19,539 11-22-2017 05:49 PM
Last Post: The Doctor
  DidiDex 1984 Levin coupe rebuild DidiDex 1 5,402 08-13-2015 03:22 PM
Last Post: DidiDex
  OST-026: "My White Hatch" oldeskewltoy 49 58,411 07-03-2014 11:56 PM
  Project "Roku-ju" TA60 Carina Motax 24 37,887 03-05-2014 10:21 AM
Last Post: Motax
User(s) browsing this thread: 14 Guest(s)
