4AGZTE
08-29-2011, 03:13 PM
4AGZTE
Has anyone ever done it? I've searched the forums here and it seems nobody has. Basically, its a supercharger feeding a turbo. No need to run an intercooler, and no turbo lag. see the following link.
http://www.srtforums.com/forums/f106/wha...vw-188374/ Understeer is when the front end hits the wall. Oversteer is when your back end hits the wall. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you! |
08-29-2011, 03:20 PM
4AGZTE | |||
08-29-2011, 03:50 PM
4AGZTE
an intercooler would be very advisable as both turbo and supercharger will heat up the air going into the engine.
AE86 ex-daily |
08-29-2011, 04:07 PM
4AGZTE
But since the turbo is fed by the supercharger, the only heat they would get would be from the engine bay. Won't a properly made heat shield and heat wrap eliminate most f that?
08-29-2011, 04:12 PM
4AGZTE
the heating is due to the compressing of the air and so unavoidable on a forced induction setup. the only case where no intercooler is used is on very low boost applications but even there an intercooler would bring benefits.
AE86 ex-daily |
08-29-2011, 04:23 PM
4AGZTE
That makes sense, thank you! I'll probably just run a side-mount IC then.
08-30-2011, 08:24 PM
4AGZTE
gt4st205 Wrote:Has anyone ever done it? I've searched the forums here and it seems nobody has. Basically, its a supercharger feeding a turbo. No need to run an intercooler, and no turbo lag. see the following link. What you are talking about is 'twincharging'. This is not a supercharger feeding a turbo. The idea is that you run the supercharger at lower revs, so that at higher revs you can get the benefit of a bigger turbo as you eliminate the lag you would have had by running an SC at lower revs. It is complicated and I have to say, seriously don't bother. Not worth the effort. If you want to run high power figures, just run a turbo. One does not feed the other. When the turbo is up and running the supercharger is in fact disengaged. You would need an intercooler however you do it, but the complexity will make it very expensive. 1985 Sprinter Trueno GT Apex 2013 GT86 Miltek Exhaust, Injen Induction. |
12-18-2012, 06:26 PM
4AGZTE
twincharged setup is totally worth it. Twincharge is not only about power but where this power is available and the point is for the power to be available everywhere. With big turbo you will get same numbers as with twincharging since in both systems turbo generates power at the top but for 4age bigger turbo will spool up at 4k and with twincharging you will hit max boost whenever you step on gas.
It is not that much complicated than turbo system alone. The piping is a bit different and you need bypass valve (not always) and thats it - the rest is same as for simple turbo conversion. Intercooler is a must and also good SA. The rest is the same. |
12-18-2012, 06:38 PM
4AGZTE
gt4st205 Wrote:Has anyone ever done it? I've searched the forums here and it seems nobody has.Seems you didn't search correctly then http://www.aeu86.org/viewtopic/--twincha...6--/t/7958 ![]() |
