4a-ge Oil Pressure Sensor Gauge, i need info
10-25-2011, 09:28 PM
Its in the middle of that doorbell like thing. You just slide the connector over it. This wire commonly lets loose, you might want to tighten the connector with a screwdriver or something like that before refitting the wire.
10-26-2011, 10:50 AM
Ivan141 Wrote:Its in the middle of that doorbell like thing. You just slide the connector over it. This wire commonly lets loose, you might want to tighten the connector with a screwdriver or something like that before refitting the wire.
The connector itself slide in one side, right?
OK, now I understand, I thought that was a connector to plug in the cable Big Grin
thanks guys!
  EUDM gauge cluster banpei 22 5,212 08-15-2023 10:48 PM
  Lambda sensor wiring sam3007 10 4,696 05-23-2022 10:00 PM
Last Post: The Doctor
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,410 08-19-2018 12:08 PM
Last Post: AlexKTM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,816 12-06-2017 06:48 PM
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,352 11-05-2016 01:34 AM
