4a-ge timing is 10 degrees BTDC, how to check ?
08-07-2007, 08:56 PM
How can I check my timing on my 4 age. I read that stock timing is 10 degrees BTDC.
http://www.heerlijklimburg.nl |
08-07-2007, 09:52 PM
you'd need a stroboscopic light to attach to youre nr1 sparkplug lead and bridge the check-engine connector. Have a look through the factory manual..it's got all the info you need.
08-08-2007, 08:14 AM
thanx I will do so.
09-09-2007, 06:22 PM
basically you hook up your timing gun, aim it at the markings near the crank pully (i.e. 20 15 10 5 0 5) and check to see if the marking on the belt lines up to 10 degrees BTDC.
09-19-2007, 08:41 PM
thank you
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,514 |
4agze timing | leon205gti | 11 | 13,664 |
04-07-2017 03:10 AM Last Post: jondee86 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,289 |
Engine Check Light at High RPM | Super86 | 8 | 8,642 |
11-03-2014 11:03 AM Last Post: Super86 |
[Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 5,482 |
04-21-2014 02:41 PM Last Post: Homem Bomba |
