4a-ge timing is 10 degrees BTDC, how to check ?
08-07-2007, 08:56 PM
How can I check my timing on my 4 age. I read that stock timing is 10 degrees BTDC.
http://www.heerlijklimburg.nl
08-07-2007, 09:52 PM
you'd need a stroboscopic light to attach to youre nr1 sparkplug lead and bridge the check-engine connector. Have a look through the factory manual..it's got all the info you need.
08-08-2007, 08:14 AM
thanx I will do so.
09-09-2007, 06:22 PM
basically you hook up your timing gun, aim it at the markings near the crank pully (i.e. 20 15 10 5 0 5) and check to see if the marking on the belt lines up to 10 degrees BTDC.
09-19-2007, 08:41 PM
thank you
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,550 07-18-2019 03:52 PM
  4agze timing leon205gti 11 13,670 04-07-2017 03:10 AM
Last Post: jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,297 11-05-2016 01:34 AM
  Engine Check Light at High RPM Super86 8 8,657 11-03-2014 11:03 AM
Last Post: Super86
  [Tutorial Video] Setting 4A-GE Ignition Timing Homem Bomba 0 5,487 04-21-2014 02:41 PM
Last Post: Homem Bomba
