4ac block with a 16v 4age head?
07-02-2008, 12:11 AM
hey i was just wondering if any of you out there knows if the blocks for the 4ac and the 4age are the same? if all the collent ports and what not would match and if the studs would match up to? pistons and crank? really all i need to know is if they use the same block. thanks
07-02-2008, 08:51 AM
Yes, bottom is the same so that can be done:
http://www.aeu86.org/viewtopic/4a-to-4age/t/5495
http://www.aeu86.org/viewtopic/ae86-sr5-...00_/t/5208
You can even put it on a 3a:
http://www.aeu86.org/viewtopic/hachigo-g...%29/t/6340
[Image: AEU86 AE86 - 4ac block with a 16v 4age head?]
07-02-2008, 09:12 AM
ok thanks man just read them and i htink its all the info i need. but i did search for the infor i just think i really suck at picking good key words lol but thank you alot for the links and info man i htink i know what im giong to do for my project now. i just need to do a bit of research to see what i should ahve saved up. i think im going to do the 4age head on my 4ac block with side draft carbs. i think it should be fun Big Grin
  4AGE cylinder head plug removal Ivan141 5 2,383 09-30-2023 09:47 PM
  Question about 4AG 20v Engine Block CHACAMAN 1 1,832 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 21,768 05-01-2021 10:09 PM
  4AGE 16V engine overheat when at high speed chenfon 32 23,726 12-31-2020 06:39 AM
Last Post: chenfon
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 7,967 11-09-2020 10:51 AM
Last Post: totta Crolla
User(s) browsing this thread:
