4ac block with a 16v 4age head?
07-02-2008, 12:11 AM
hey i was just wondering if any of you out there knows if the blocks for the 4ac and the 4age are the same? if all the collent ports and what not would match and if the studs would match up to? pistons and crank? really all i need to know is if they use the same block. thanks
07-02-2008, 08:51 AM
Yes, bottom is the same so that can be done:
http://www.aeu86.org/viewtopic/4a-to-4age/t/5495 http://www.aeu86.org/viewtopic/ae86-sr5-...00_/t/5208 You can even put it on a 3a: http://www.aeu86.org/viewtopic/hachigo-g...%29/t/6340 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
07-02-2008, 09:12 AM
ok thanks man just read them and i htink its all the info i need. but i did search for the infor i just think i really suck at picking good key words lol but thank you alot for the links and info man i htink i know what im giong to do for my project now. i just need to do a bit of research to see what i should ahve saved up. i think im going to do the 4age head on my 4ac block with side draft carbs. i think it should be fun
4AGE cylinder head plug removal | Ivan141 | 5 | 2,076 |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,634 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 20,809 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 21,574 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,348 |
