4agZe problem solved - 99% IC problem
07-02-2012, 10:19 PM
Oh HELL NO! I am not gonna do that yet then hahaha.
I will just remove the SC pulley and get a smaller belt - than at least I can drive my 4agze without the Z. and with less power.
But first I gotta see if it works or not. With the smaller belt.
-DWG- Drift Wolf Gaming
07-03-2012, 03:43 PM
Tomorrow I will go back to the shop with the belts as today I tried 3 different types and they did not fit... Either too small or too big.
So tomorrow I get to test 2 other belts.
Then the supercharger pulley will have no belt running it.
Only my waterpump and crankshaft and tensioner will run and my alternator has its own belt.
I hope it will work so that I can least go to the world-record attempt this saturday in Gemert the Netherlands.
And I also want to take my AE86 to Lelystad because I am invited to DRIVE THE NEW GT86 !
So the AE MUST BE DRIVE-ABLE!
07-03-2012, 05:08 PM
Thats something i have also noted in my agenda since sc is forbidden for rally/criteria.So i will need to remove the sc and run a belt like you try to do now.
Did you try any porsche belts,i can't remember why but i think i heard it somewhere that it should work.Can't give you any confirmation on itSad
07-03-2012, 06:08 PM
[Image: AEU86 AE86 - 4agZe problem solved - 99% IC problem]
Gonna do it like that. So that I can at least drive - and then eventually take off the supercharger pulley to see if its broken.
But lets just hope it will work like this.
Tomorrow I will get 2 belts to try out if its the size I can use.
If that doesn't work I will ask them for a porsche information tho I doubt they have that...
Will keep you (all) posted.
07-03-2012, 08:51 PM
Yes thats the same setup i will need when i dont want to use sc
I can't remember where i heard the bit about the porsche belt but it can be a lead if the other belts dont work.
the bilstein shockdampers from a porsche van also be used for an ae86,thats how mine are.
07-03-2012, 09:53 PM
If all else fails you can always use à couple of big tie-wraps ;-)
AE86 Levin
07-04-2012, 10:31 AM
LOL... Then I would rather use some shoe-laces...
Anyhow - after driving back and forth for the 6th or 7th time to that parts shop I have a belt now that I think I had before but its too tight...
I need to make it a little bit more flexible so I can put it on.
It's BELT :
5PK718
It's a little too tight just a bit lower than the edges but this should work when I get it on... Maybe I need to leave it outside in the sun or maybe I need to put it in hot water for a few seconds or minutes so I can pop it on.
07-04-2012, 12:24 PM
ik heb toevallig nog een mooie 16 klepper liggen, interesse??? Big Grin
drift ae86:308bhp/435nmEDIT:384pk/498nm!!!!>now DEATH)))
07-04-2012, 12:28 PM
jasper Wrote:ik heb toevallig nog een mooie 16 klepper liggen, interesse??? Big Grin
Ik heb nog altijd interesse in wat anders Jasper en misschien heb ik in de nabije toekomst ook nog wel interesse in die 16 klepper ja... (zeker mijn oude blokkie) PM me maar alle info ideeen en prijzen die je in je hoofd hebt.
Thanks.
07-05-2012, 03:16 PM
5PK718 did not work - way too tight - didnt get it over...
So I cut one belt I had laying around (found it by accident) and I need 5PK723.
But that one is nowhere to be found.
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 7,603 07-28-2022 10:48 PM
  4agze wiring problem leon205gti 15 23,044 01-21-2017 09:19 PM
Last Post: leon205gti
  Questions about brake boosters and master cylinders---SOLVED T_AE86 17 25,100 02-02-2012 07:54 PM
Last Post: T_AE86
  [4AGE] ignition timing problem -> SOLVED !! eg6maxx 16 49,965 05-17-2011 11:48 AM
Last Post: eg6maxx
  4AGZE problem...I Need help please guys ash16valve 6 7,100 12-11-2009 04:48 PM
Last Post: ash16valve
