4age 16v engine which is it ?
10-01-2014, 10:52 AM
hello my friends,
a good friend bought a celica but has a 4age 16v inside....We need immediately spark plug cords and a distributor cap.I dont know which exactly motor it is .....Has no tvis and it confused me...very much...help please 4age 16v to FR 20VT |
10-01-2014, 11:43 AM
That is a regular 4AGE redblack top!
NonTvis and 134bhp |
10-01-2014, 01:17 PM
from AE92
10-01-2014, 02:12 PM
finally it is a non tvis but it is conversion and the cabling it is from first gen as you can see....
10-01-2014, 02:14 PM
Converted smallport from an ae92 gt year 90-93 i think
10-01-2014, 07:52 PM
from your 2 pictures all you know for sure is... it has fwd engine mounts attached, and it has a modified smallport manifold.
It still could be a largeport with an adapter... or it could be a smallport.... one thing it isn't... is a rwd only Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-02-2014, 03:01 PM
(10-01-2014 07:52 PM)oldeskewltoy Wrote: from your 2 pictures all you know for sure is... it has fwd engine mounts attached, and it has a modified smallport manifold. hello dan, it should be the smallport finaly cause if you watch the distributor closely wou will see the small port spark cords and plastic bases among the spark pipes 4age 16v to FR 20VT |
10-02-2014, 08:18 PM
It has MAP sensor and O2 or not?
My car even older than I. Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD |
10-04-2014, 07:56 AM
Good morning ,it has map and it has not an o2 sensor
Sent from my SM-N9005 using Tapatalk 4age 16v to FR 20VT |
10-05-2014, 10:55 AM
(10-04-2014 07:56 AM)Apsogos Wrote: Good morning ,it has map and it has not an o2 sensor Looking at the intake manifold it should be a smallport. But as mentioned it could have an adapter. (why would you modify an FWD intake if you don't use the normal head with it) Easiest way to find out is take off the intake manifold. On the intake port side you can easily see if it is a smallport. Then apart from everything, they could have swaped the smallport head on an old 7 ribbed non oil squirt lower block but lets stay positive and think its an redtop 4age with oil squirters :-) Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
Which Color??? | oldeskewltoy | 11 | 12,604 |
05-27-2014 04:22 AM Last Post: AlexKTM |
which is the best quality flywheel brand for 4age smallport? | LyndonAE86 NZ | 8 | 13,291 |
12-06-2012 01:20 AM Last Post: Bean |
Velocity Stacks - Which, Where, How much? | apardal | 9 | 9,171 |
04-30-2008 03:38 PM Last Post: isac |
Which brands would you be interested in for your AE86? | speed-inc | 27 | 22,443 |
12-12-2007 12:03 PM Last Post: speed-inc |
Which brand wheels are these?? | DJexor | 1 | 4,226 |
09-16-2007 06:36 PM Last Post: DJexor |
