4age Smallport o2 sensor and knock sensor question
02-01-2011, 05:50 AM
Anyone using a factory smallport loom with smallport 4age? I HAVE QUESTIONS!!
Firstly, I have just had an o2 sensor put in and need to know if its the black wire with the grey covering and round yellow connector? Secondly, I need to find and install a knock sensor. Apparently there are 3 possible types that it could be. Does anyone have a part number/brand or picture? Also, is the knock sensor wire the black with brown covering and round grey connector? Your help is greatly appreciated http://86life.wordpress.com/ |
02-01-2011, 09:38 AM
I have a smallport knock sensor.
I can give you the P/N and take picture after my work (I also have the full wiring loom of the AE92 where I have taken the engine so I can tell you what kind of connector is used for the Knock Sensor) |
02-01-2011, 09:46 AM
That would be great! Thanks so much!!
02-02-2011, 12:03 AM
The knock sensor have nothing written on it (just a big M and 7 1 015) but I found the toyota part number: 89615‑12020
I also take a picture: I hope it will help you. |
02-02-2011, 09:50 AM
Perfect! Thankyou.
Smallport coil | totta Crolla | 2 | 1,581 |
08-12-2022 11:03 AM Last Post: totta Crolla |
Smallport inlet manifold | totta Crolla | 6 | 3,122 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
4A-GTE 7-rib smallport | nyberrg | 5 | 6,053 |
05-24-2017 09:24 PM Last Post: krullibull |
Smallport Fuel Rail | Alex170984 | 2 | 4,424 |
11-19-2016 08:44 PM Last Post: Alex170984 |
Smallport Head swap | Alex170984 | 9 | 8,853 |
06-09-2016 12:11 PM Last Post: ZDoman |
