82mm Stock compression Pistons
11-24-2021, 01:07 AM
Hi!
I'm in the process of getting my 4AGE back in stock form and I'm trying to reuse my original block that had 81,5mm wiseco pistons and 20k miles after had some kinks on them that eventually scratched the cylinder bores. I can either get some sleeves and stock pistons or go with a 82mm piston setup. I'm not fond of putting new sleeves on 4AGE's, but i'm finding it very difficult to get stock compression pistons with 82mm of bore. Does any of you know if there are brands that can get me to where I want to be? The goal is to build a stock 4AGE for daily use. Good engine blocks are getting each day more difficult to find and I would also like to keep mine, as it is a 7 rib and the 40mm rod journal crankshaft is ok. Any input will be appreciated! |
11-24-2021, 01:42 PM
If you cannot find any piston?? You could try this less than perfect solution. Rock Auto has .020" oversized pistons and rings for the SOHC engine. For $52 US dollars + shipping. You could use a thinner head gasket to bump the compression back up to stock or even higher. Cosmetic makes several different thicknesses of head gaskets for about $85USD. You may have other HG suppliers in Europe.
Dave W |
11-24-2021, 03:31 PM
Don't know where you are from but there is something here on Marktplaats (Market Place) here in the Netherlands
https://link.marktplaats.nl/m1773995195?...nt=app_ios |
11-24-2021, 03:51 PM
What stock compression ratio are you targeting ?
-9.4:1 bluetop (super lame) -10:1 European bluetop -10.3:1 smallport -10.5:1 Silvertop (that the one I would pick for a daily drive) -11:1 Blacktop Even with everything else stock, having more compression is a good thing. Anyway, most piston manufacturer can do custom jobs. Get in touch with Traum pistons or you can try Matrix Garage (but the guy has disappeared for a long time now, not sure they still do business): http://www.matrixgarage.com/products/mg-...-largeport |
11-24-2021, 04:26 PM
I’m looking to keep stock CR@10:1.
Already got a quote from wossner pistons at 217€ Each piston. It’s a little steep! |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,377 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,420 |
working out compression ratios | kazi | 2 | 3,539 |
07-16-2019 08:22 PM Last Post: oldeskewltoy |
Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 5,579 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,333 |
10-25-2016 09:18 PM Last Post: oldeskewltoy |
