'84 AE86
11-08-2008, 04:31 AM
'84 AE86
I've got a 1984 Ae86 Sr5 (California Car) that's Carborated, Rwd 5 speed manual with no aftermarket changes in it. I've changed the spark plugs, distributor cap, and oil in hopes that that would help it pass emissions, but it didn't work. The car has around 210K miles on it and is just a daily commuter car. I really want to keep it, but I don't know how to reduce the amount of hydrocarbons that the car is producing! The number should be 220, but it's around 440 instead. It idles higher than normal until I drive it on the freeway for a while as well. Any ideas on how I may be able to fix this issue?
Thanks in advance!
11-08-2008, 11:59 AM
'84 AE86
Carburettor rebuild? Problem is most likely originating from the carbs.
11-08-2008, 06:23 PM
'84 AE86
ok, I'll have to find out how I can go about doing that then!
11-09-2008, 09:42 AM
'84 AE86
Take a look at the carb and figure out the make and model. Then
google "rebuild + make + model". Should come up with something
useful Smile
Probably be a good idea to research the common factors causing
high hydrocarbon readings first. There may be other things besides
the carb that need attention e.g. fresh plugs, clean air filter, fresh oil,
ignition timing etc.
Cheers... jondee86
