A/C idle up on my GZE
08-15-2011, 07:42 AM
Hi guys,
When I switch on my aircon the revs of my engine drops quite a bit (approx 200 to 300) and I feel a large power drop.. When during driving when the a/c circuit disengages the compressor I feel the engine becoming lighter and then when it comes on again there's a huge power loss.. I assume the power loss is normal but I didn't feel this much of powerloss while I had my 4AGE when the a/c comes on.. No one seems to know how the a/c idle up works in the GZE.. Does anyone know how this works? CUrrently when the car is running without a/c it idles around 800 and then if turn on a/c it'll drop to like 600 or 700 at that low point.. But on a cold start the idle start around 1200 and if I turn on a/c it drop to around 800.. How can I fix this? I was told that there a vacuum system that would put open the butterfly based on its setting.. Is this correct? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
08-15-2011, 08:17 PM
I know there should be a seperate vsv on the normal 4AGE for the aircon that will increase revs when engaged, so most probably such a switch is also available on the GZE.
Perhaps this topic can be of any help: http://www.aeu86.org/viewtopic/vacuum-se...lp_/t/6761 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
08-17-2011, 05:11 AM
You need to bear in mind that both the AC and SC runs with belts connected to the crank pulley so it could play a role on your idling and loss of power.
Current - 2006 Run X RSI TRD spec Current - 1991 AE92 Conquest 4AGTE Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM) Ex - 1983 1.8 SE Liftback(headworks and side draughts) |
08-19-2011, 10:50 AM
Yes, I understand the power loss but I think if the engine could revv up then I think the power loss won't be felt this much..
I'll keep updated when the mechanic looks at this problem.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,424 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,138 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
exhaust odor/idle MOT issue | Ryo | 7 | 7,248 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,135 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
Silver top low idle | AlexFourTwenty | 7 | 10,135 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
