A Portuguese Hachiroku in Belgium (lots of pictures)
01-02-2017, 10:13 PM
(This post was last modified: 01-03-2017 11:49 AM by Lt86.)
Hi everyone,
In March 2013 I was lucky enough to track down a red 1986 AE86 Levin coupe in Portugal. The car was located more than 2000 km from Belgium and it took me a day or so to decide whether the car was worth the trip. It would later turn it out was! I hopped on a plane a week later and arrived in sunny Portugal to find her sitting pretty in the previous owners garage. A few minutes later we started the car and I took it for test drive in the Portuguese mountains with the owner next to me. Never having driving an 86 before I instantly liked the go-cart feel of it. The engine had a smooth power band, no weird noises, brakes were good. The only downside was the silencer was big enough to fit my luggage but the engine was still running the original exhaust header. Exhaust smell was horrible. While cruising on the highway it produced a droning sound which would drive me mad during the long trip back. 1-2 2-2Anyways, already fallen in love with it we made a deal and I took it home. Due to some problems with my GPS it turned out to be a 2500km and 26 hour trip with no rest, except for fuel and coffee. This road trip was absolutely amazing and I really got to know the car. The owner had told me it consumed just a little bit of oil so he had given me a liter for the trip. On the first stop for fuel I couldn't even get a measure from the dipstick so it turned out it was consuming A LOT of oil. Every fuel stop I had to add atleast a liter of oil. Only after I got home I noticed one of the hoses running to the oil cooler was damaged. The engine was fine, it was the hose that had been dripping constantly. Easy fix so apart from spending a fortune on oil priced as gold I was happy this wasn't anything serious . So, first things first. Very curious to find out what was beneath the ugly looking seat covers so I took em off. Near immaculate seats below them and some weird powder. 4-2 3-2 5-2Bought a matching key chain. 6-2 The heather hadn't been working which was rather annoying during the trip. In heinsight this actually was a good thing because being freezingly cold kept me from falling asleep. If you're up long enough there comes a point pouring in caffeine isn't going to help anymore and with well over 35 hours of no shut-eye I needed all the help I could get. A very common problem is a clogged heather core and flushing it did the trick. I'm trying not to add too many pictures but there was lots of sand in the heather core and the coolant system itself was running mud instant of coolant. 7-2Gave the engine an oil change and a new filter, put new transmission- , diffoil and new spark plugs in it, lubricated the hinges,... etc. All the typical stuff anyone does when buying a new old car. I also poured a bottle of Swiss Chemicals Warm up Gold formula in the oil and a bottle of the same brand in the fuel to clean injectors. All of the above really made the car run a lot happier. These will do the trick. 9-2Ok, so far so good. No big optical changes. Gave the car a good wash and found out more things to do as she was being driven nearly daily. 10-2On a later drive, for some reason, my idle didn't want to come down after the car was heated up. The engine started revving up to about 2000-2500 RPM, came down to stationary rpm and kept repeating this over and over. In combination with that insane exhaust facing a red light was horrible since it made me look like an ***hole who wanted to race everyone. At the time I didn't know how the whole throttle system of the AE86 worked so it was nice to learn. The throttle body has a little wax pellet in it which acts as a blockage when it melts due to the warm coolant. The molten pellet closes an opening in the throttle body reducing the amount of fuel that goes into the engine and lowers the rpm when the coolant is hot enough or something like that... . Having air in the system apparently causes the same effect so I bled the system thoroughly, took the TB apart and removed all the crud with a steamer. 11-2Problem solved! No more angry people giving me the stink eye. However, that exhaust was still bothering me. The entire system was in poor condition so I decided to order a new one. Martelius hooked me up with one that fits the LHD AE86 real nice. I picked one with an extra silencer so now it's possible to listen to the radio but still hear the engine when you give it the beans. A friend once said it sounds like a mix between the high revving 4 cyl and a rotary engine. Can't say I'm not happy with that ![]() 12-2 15-2 16-2An unexpected heavy rain storm pointed out that water was leaking inside the trunk. This came as a shock since I realised how lucky I was the trip home from Portugal was, given cold, but sunny! Apparently no gaskets were fitted to the taillights. Water dripped down from the roof, followed the curvature of the trunk lid and got caught behind the lights. Ordered new ones straight from Toyota. 13-2 14-2 Just in time for a trackday and not to worry about too much db. Picture credit goes out to Dennis Noten Photography: ![]() While driving home a few days later I came off the highway and the engine stalled. When trying to get the car going it was making all these weird noises and it wouldn't run properly. After towing it home we found the cause: a blown headgasket. It had ruptured in between 2 cylinders so there was no coolant leaking and the engine did still run, but both pistons were working against each by pressurising the other one on the upstroke through the broken gasket. 18- 2-2Since the head was off anyways I decided to overhaul the entire engine. Fit some new parts (Exedy light flywheel, slightly bigger clutch from the MR2, new waterpump, belts, gaskets,...) and I bought a slightly lower TRD metal head gasket to prevent from something like this happening in the future. New valves were installed and the head came back super clean from the machine shop. 19-2 20-2 21-2Painted the camshaft covers, wrapped the exhaust header with heat wrap cause when the engine was taken out I noticed it had actually molten the distributor cover, this had a big hole in it . I'm prolly forgetting a lot of stuff that has been done but there is more than I care to add at the moment. So this is the engine back in the car. 22-2Fitted a Momo steering wheel which at a later stage was swapped for the bigger momo I had in my Starlet. The smaller one made the steering a little too heavy for my taste and catching the car when the rear got loose was more difficult. DSC_0006-2The car wasn't sealed on the underside which was great because I really got to see the true condition it was in. NO rust . Belgium weather isn't anything like Portuguese weather so it was time to start protecting it. before 24and after 25 Now, the compomotive rims were really cool and made the car look a lot more beefy than it actually was. The only problem was that they were quite wide and hitting the body at times. Especially bottoming out at fuchsröhre at the Nurburgring was suicide. So I sourced a set of original wheels to install whenever I felt like it. Downside is that I didn't like the ET of them. Nothing to worry as I would find a different set of rims later on. 26Since the handling of the car still wasn't all that great I fitted adjustable Whiteline anti-sway bars front and rear, a driftworks CS2 coilover set, steel brake lines and Mintexx performance pads. It handled like a totally different car and I loved it! 27-2 28-2 29-2![]() At this point I was pretty happy with the total package. I didn't list all of the stuff I did. I actually worked on the elektric stuff quite a bit, the car has NOS new headlights, new blinkers, all sorts of stuff all over that has been modified or replaced to make it a better package without changing the look too much. 30 Last time at the Nurburgring and frankly on a lot of the horrible roads overhere the Compomotive rims were still hitting the fenders at times and I was scared of eventually damaging them so I sourced a set of Hoshino Impul turbo fan rims. Can't find a decent picture with the covers mounted at the moment so I pulled one of my instagram. I keep the covers in a box so they stay in good condition. 33 and the car now: 32 More to come... If you like to see more pictures of the car, my instagram is 'timeightsix'. Kind regards! |
01-03-2017, 01:12 AM
Nice to see that the car went to good hands! Keep up the good work!
Jorda MotorSport Keto Beams Project |
01-03-2017, 10:51 AM
NICE!
01-03-2017, 01:31 PM
Oh man... That is delicious.... Keep that car alive!
![]() Regards |
01-04-2017, 03:22 PM
It already was a nice car to look at, but your upgrades and the Hoshinos make it look awesome!
BTW: are those mods and rims allowed for the Belgian MOT? I can remember some members had serious issues with aftermarket stuff. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
01-04-2017, 04:38 PM
(01-04-2017 03:22 PM)banpei Wrote: It already was a nice car to look at, but your upgrades and the Hoshinos make it look awesome! The coiloverset, the anti-sway bars, braided brake hoses,... are not allowed in Belgium. Luckily, at the moment and for some time now, you only have a once-in-a-lifetime MOT check for oldtimers . So if you present the car somewhat original at that stage, nobody is going to know if you fit a beams engine in it afterwards. Other rims are allowed but I'm not sure if these would pass. They are 14" as my original ones but a little bit wider. Mine passed with the compomotives though .
01-04-2017, 04:52 PM
Never knew your car... And i'm probably the portuguese AE86 event planner...... But it looked by the time it was on sale really damn nice, problem is, we in Portugal fear those "beauty" cars because most of the times they are filled with issues......
Luckily or not yours is in great shape, and with some damn nice upgrades.... Keep that portuguese relic for many years.... Owning another portuguese AE86 now transformed by me into a Trueno and loving these cars more and more everyday that story of yours is really damn nice.... We want more mods! That is the 86 spirit!
01-04-2017, 06:45 PM
Woow, that´s a great story until now.
That´s the plan I will make it in the (hopefully short) future, as well! And in the time between, I am working on a 4A-GE for fun. @Lt86, please tell me when you are in Adenau (Nuerburgring), I am living there, and I would love to see your car in real-life!!!!! Kind regards |
01-04-2017, 06:47 PM
(This post was last modified: 01-04-2017 06:55 PM by Lt86.)
Thanks Pack!
Well, from what I learned the car was on sale for quite a while but it never traded owners. One other guy flew over from Spain, I believe, to check it out. He gave a downpayment but never picked it up afterwards. My initial thought was the same. The previous owner is a really good photographer so the pictures in add were so good, the price was so good, it had to be fake, right ? But after sending some e-mails it all seemed legit. Almost seems meant to be that I was able to buy it. more modds: considering on doing some more work. I have been thinking of upgrading the diff, add cams,... I'd love some ITB's but this tends to become very pricey very quickly. We'll see what the future holds. (01-04-2017 06:45 PM)flymat Wrote: @Lt86, please tell me when you are in Adenau (Nuerburgring), I am living there, and I would love to see your car in real-life!!!!! Deff. have some more trips planned for 2k17. If I remember I'll be sure to tell you! Here are some pics of this year. 34-2 35-2 36-2
01-04-2017, 07:48 PM
That is my dream and hopefully in 2018 i'll travel do the Ring to get my chance.....
| NBU is HachiRoku | NBU | 66 | 98,510 |
12-12-2016 06:15 PM Last Post: pack |
| levin from Belgium - demee76 | demee76 | 46 | 76,075 |
08-28-2015 03:06 PM Last Post: demee76 |
| Belgium project | Roger | 12 | 21,327 |
08-03-2015 08:46 PM Last Post: Roger |
| belgium ae86 | boedtsie | 8 | 15,235 |
06-01-2015 05:25 PM Last Post: Lt86 |
| '85 2door from Belgium | HybriD07 | 507 | 665,412 |
05-23-2013 11:43 PM Last Post: kowalskitk4 |
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c1.staticflickr.com/1/641/31215225824_c74299b63a_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c1.staticflickr.com/1/711/31215228744_b2c1f9d504_z.jpg)
. ![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c5.staticflickr.com/1/539/31908988932_4df4f85608_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c1.staticflickr.com/1/649/32017963696_528be628da_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c5.staticflickr.com/1/708/32017962916_0267ca7284_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c2.staticflickr.com/1/616/32057128385_d76a41b169_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c6.staticflickr.com/1/672/31939286341_df71a34e41_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c6.staticflickr.com/1/421/32057313285_56815acd03_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c2.staticflickr.com/1/644/32057442865_5e10054271_z.jpg)
. Having air in the system apparently causes the same effect so I bled the system thoroughly, took the TB apart and removed all the crud with a steamer. ![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c5.staticflickr.com/1/770/32018608636_c6c16d55bb_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c3.staticflickr.com/1/319/31216654634_5994510380_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c5.staticflickr.com/1/599/31683141980_faeca4885a_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c2.staticflickr.com/1/468/31247934793_1bd12ddd65_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c3.staticflickr.com/1/748/31909948042_6bd0f1c28b_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c7.staticflickr.com/1/722/31683015350_9b5b2f039f_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c4.staticflickr.com/1/325/31247970963_83a8503612_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c3.staticflickr.com/1/607/31683346370_79faa10c80_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c1.staticflickr.com/1/594/31910411432_8774aa0a79_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c6.staticflickr.com/1/286/31940522781_9be1c7162b_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c7.staticflickr.com/1/694/32019410326_14fa84fc9b_z.jpg)
. I'm prolly forgetting a lot of stuff that has been done but there is more than I care to add at the moment. So this is the engine back in the car. ![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c7.staticflickr.com/1/494/31683517390_be77ea667a_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c6.staticflickr.com/1/533/31248324853_9a91b6f0e5_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c5.staticflickr.com/1/392/31217476484_f7b41e7992_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c3.staticflickr.com/1/506/31910630562_bedca844cf_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c3.staticflickr.com/1/423/31910694602_53484fe7b5_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c1.staticflickr.com/1/388/32019850856_91edece962_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c1.staticflickr.com/1/637/31217671184_bffa266fec_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c4.staticflickr.com/1/365/31940917971_31489e4bb1_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c8.staticflickr.com/1/697/31940983991_a1186d6106_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c4.staticflickr.com/1/554/31248785683_c5940ebbb8_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c7.staticflickr.com/1/730/32019964646_afaaeac609.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c5.staticflickr.com/1/330/31684132620_50c8ae5ffe_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c1.staticflickr.com/1/769/31954523592_a0fd93a70e_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c5.staticflickr.com/1/275/31954522892_b2c9f020b5_z.jpg)
![AEU86 AE86 - A Portuguese Hachiroku in B... pictures) [Image: AEU86 AE86 - A Portuguese Hachiroku in B... pictures)]](https://c7.staticflickr.com/1/429/31954521622_0f5cdfe7df_z.jpg)
