AC problem? Idle problem?
08-18-2009, 09:37 AM
Hi ALL, I have another problem no my 86 again.
When the AC is off, everything is fine, idle steady, no problem at all.
But, when I have the AC on, once I rev up the engine and let go of the pedal, the engine rev will drop very quick and sometime cause the engine goes off, any idea?
I check the hose (N-port) from the throttle body connect to a small silver reservoir, but again, everything is fine.
Thanks to advise!!
08-18-2009, 05:13 PM
Sounds like your missing some kind of idle-up arrangement. If I'm not mistaken the ECU has an input for this that raises the idle when the AC kicks in. Dont ask me where to find it though.. have never seen a hachi with AC in my life.
08-19-2009, 02:08 AM
Here is 35 deg. in HK during the day. so, better have AC la.
Will try to check the idle up thingeee and hose, etc, etc, and give it a good clean, see if it can solve then....will try to do it late when have time.
  No idle below 2000 rpm rich running Steller Engineering 3 1,730 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 8,192 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 7,812 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 5,404 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 10,656 10-16-2017 10:22 PM
User(s) browsing this thread:
