AE86 Alternator
09-02-2009, 10:33 AM
AE86 Alternator
Hey guys!
My alternator is giving me trouble . Is there any replacement I can use, or maybe i can swap internals from another more common car? |
09-03-2009, 07:14 AM
AE86 Alternator
Snejk Wrote:Hey guys! download the AE86 manual do ur own testing on ur alternator conductivity and stuff and that s all then see if u want to replace the alt cause u just said ,i HAVE a alternator problem but what kind of problem? :S |
09-03-2009, 09:56 AM
AE86 Alternator
Where can I find the manual?
The problem is like this: I turn on the car in the morning, everything is fine. I drive for 10-20 km, everything is fine still. I get stuck in traffic, something heats up, the red light starts cutting in more and more, to the point when its lit up all the time. When I bump into a hole, the light will flicker. When I step on the gas, the light will flicker also, sometimes turning off, sometimes turning on. Does anyone have any idea.. I've taken the car to the electrician 10 times at least. |
09-03-2009, 12:23 PM
AE86 Alternator
you can get one from a civic 1.6 vti (EG), and change the pulley from the AE86
09-03-2009, 12:26 PM
AE86 Alternator
On the front page you can see a menu on the left side of the page which has a link almost at the bottom of that menu which says "AE86 manuals".
Or just use this link: http://www.aeu86.org/index/technical-ae8...topic=5158 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-25-2009, 03:18 PM
AE86 Alternator
The connector on the wiring harness is losing contact more and more.. That was the problem all along.
20v swap alternator | izanagi | 3 | 4,991 |
12-15-2016 01:11 PM Last Post: pack |
85 amp alternator? | heshan | 4 | 7,722 |
06-12-2012 08:03 PM Last Post: heshan |
Help! Lost tachometer, water t. gauge, alternator wont charg | Saber | 9 | 12,493 |
05-21-2012 08:06 PM Last Post: Saber |
alternator | Roger | 12 | 16,638 |
06-09-2009 09:17 PM Last Post: Roger |
Alternator rebuild | max_ae86 | 6 | 6,819 |
04-22-2008 09:42 AM Last Post: max_ae86 |
