AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
10-10-2009, 11:35 AM
Post: #181
soooo much win conrad congrats
clutch kick, switch, tree .... oowwww |
10-17-2009, 09:04 AM
Post: #182
you do know that i make a harmonic balancer but it has only 1 ribe set up for the alternator ,i will take pics when i get around to it ..also make a 12 liter air box assembly so the 2 stage sits inside with a 6 inch hole for a whitches hat unifilter to sit in
10-17-2009, 07:51 PM
Post: #183
Glenn, cheers for the info I'm going to run without the harmonic balancer for now and the stage two's are coming off in favour of some nice trumpets. The new airbox will be fabbed once the engine is in the car and I know how much room I have to play with between ITBs and the inner wing
I'm currently taking HRT ~ Hachi Roku Therapy |
10-18-2009, 05:55 AM
Post: #184
ok some pics of the race balancer and 2 air boxes as welland last pic with it on the car
10-19-2009, 12:36 AM
Post: #185
WOW!!! Check the volume of that carbon airbox.... It's going to resonate with the induction pulses and sound mental! - looking forward to hearing this!!!
VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
10-19-2009, 04:15 PM
Post: #186
Looking good Conrad
You may need to drop the front brackets that hold the tension rods and ARB as the ARB will foul the crossmember when the car is on the ground fully loaded. Im doing the F20 swap at the moment and I ran into this problem and Im running the same crossmember spacers. Regards Maurice |
10-19-2009, 07:45 PM
Post: #187
Celica RA45 Wrote:ok some pics of the race balancer and 2 air boxes as welland last pic with it on the car Glenn, pm me with details of the carbon airbox please, price and dimensions and some pics of the filter arangement if possible. Conrad I'm currently taking HRT ~ Hachi Roku Therapy |
10-19-2009, 07:47 PM
Post: #188
Maurice Wrote:Looking good Conrad Cheers Maurice, I'm sure the guys will sort it when they sit it down. Good news.... the car will be sat on its wheels by Friday!!!!!! YEE HA! Its off to paint on Monday I'm currently taking HRT ~ Hachi Roku Therapy |
10-20-2009, 04:03 AM
Post: #189
Oops. Assumed it was already a feature. Open throttles sound fantastic too. Just a thought - does the airbox close and stay tightly closed? Have the ones been used prior rattle at all? Any sound clips?
10-21-2009, 07:48 AM
Post: #190
ok the carbon air box is the small 1 and is 450 plus postage and the 1 on my car which is 12liters in capacity is 250 plus postage
ae86 racecar with beams engine | bakonick | 148 | 164,150 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 89,077 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 736,478 |
Beams Levin build | mannix20vt | 5 | 9,305 |
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 88,675 |
