AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
06-12-2010, 10:57 PM
Post: #241
I think its cool that you are doing something different to everyone else. 10/10.
http://86life.wordpress.com/ |
06-13-2010, 05:40 AM
Post: #242
Very Porsche 944...
06-14-2010, 03:47 AM
Post: #243
dont cut the bumper just pack it out 20mm where it bolts on to the bumper stays
06-16-2010, 06:29 AM
Post: #244
As the bumper usually fits other AE86's no problem - so it's unlikely to be the bumper that's at fault. I'd suggest it's the different front panel that's causing a problem there, Conrad.
I'd wait to fit the headlights, grille, etc. first before cutting the bumper - to make adjustments to it all lines up OK. HTH, Miguel. VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
06-30-2010, 07:37 AM
Post: #245
I don't suppose you have a photo of the rear wheels fitted? I'm looking at getting a set of exactly the same spec wheels but in black. Cheers
http://www.super86.co.nz |
06-30-2010, 10:42 PM
Post: #246
very clean car i love this proyect i whant to make tis same roll cage and change my cusco
![]() my ae86 drift car (Dominican Republic) |
07-09-2010, 03:48 PM
Post: #247
Conrad Wrote:Update, Front wings finished. The bumper was fitted up and it looks like the bumper edges need adjusting to follow the arch profile better. (aftermarket bumpers for you) Agree with Miguel on that one - fit up lights etc before chopping up the sides of bar. Also are you using a custom bumper bracket with the kit or modded OEM ones? I'm running 15x8.5J's on the front of mine and with +4 degrees caster they fouled the bumper edge (common with wide front wheels/aggressive offset) I actually mounted the OEM front bumper brackets further forward using the front-most of the 2 top holes on the chassis rail and some 1" ali spacers on the main bolts that go into the chassis rail from the front. But If you're using a custom front bar mount for the Origin kit you could just tweek it a bit to give extra clearance ![]() ![]() Here's the result with Origin front fenders (note I did not re-radius the arch, just trimmed the inner lip/tab the bumper attaches to) ![]() RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式 |
07-09-2010, 10:55 PM
Post: #248
The problem is that you have pulled the arch out, therefore the wheel arch line has moved foward and is now misaligned with the bumper. If you cut it it will look crap. Packing it out is a good answer. Kid Karola's looks good so no reason that yours wont too.
07-10-2010, 05:40 AM
Post: #249
THIS BUILD BY FAR IS THE BEST I HAVE EVER SEEN!!!!!wISH I LIVED CLOSED TO U WOULD LOVE TO SEE IT UP CLOSE... GLWB
*yes i had to scream LOL |
07-13-2010, 04:09 AM
Post: #250
I certainly did not want to pack the front bumper out, that is a bodge, the picture above looks terrible, its just not right and that is not good enough.
The job has been completed correctly to keep the circle of the arch. Front bumper to wing alignment corrected. ![]() ![]() ![]() and..... work on the rear arch flares is under way ![]() ![]() ![]() ![]() Slow but steady progress.....no rush now with me being overseas ![]() I'm currently taking HRT ~ Hachi Roku Therapy ![]() |
ae86 racecar with beams engine | bakonick | 148 | 156,794 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 84,210 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 704,648 |
Beams Levin build | mannix20vt | 5 | 8,861 |
01-27-2016 12:39 AM Last Post: mannix20vt |
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 85,432 |
06-22-2015 02:56 PM Last Post: Uzelac |
