AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
06-19-2013, 10:51 AM
Post: #401
Ivan, thanks. They are not all 90 degree, just the starter connectors(which is just a bulkhead connector for power rather than a mil spec connector) and 2 x 90 degree mil specs where the steering column passes through the bulk head as we didnt want to have to loop out the cables where the pedal box will sit.
It progressing slowly, not as fast as I would like but after about 5 years its pointless worrying about it now. Hopefully it will be running in the next 4 weeks I'm currently taking HRT ~ Hachi Roku Therapy |
07-17-2013, 10:43 PM
Post: #402
A small amount of progress but going in the right direction :smthumbup
Battery and Isolator mounted Rear screen mounted into the tailgate. Front screen installed into the car :smthumbup ....and we are struggling with the side windows thanks to the dumb ass fabricators for losing 95% of all my window rubbers and trim, it's proving difficult to obtain the right parts for a 25 year old car :frust: I'll keep looking.... I'm currently taking HRT ~ Hachi Roku Therapy |
12-11-2013, 12:05 AM
Post: #403
A few updates....
Wiring, MoTeC PDM, MoTeC ECU is powered up, main fuel lines are run, FPR is installed, fuel pump is mounted, all windows are nearly in, door handles and locks are fitted, hydraulic handbrake has been modified ready for installation. To do.... Fit screen wiper, motor and mechanism Fit general shell hardware (trims, scuttle etc) Trial fit seat in both sides, check for clearance Final fit of seats Final fit of harnesses Fit rear quarter lights Fit quarterlight window trims Fit rear bootlid Make and fit bootlid stops Fit bootlid tiedowns and brackets Fit bonnet aerocatches and fabricate pin mounts. Fuel pump and filters, plumb in to B/H fittings Modify radiator and plumb in with header tank Fit electric cooling fan Fit windscreen washer system Modify airbox, fit latches, and fit. Fit trumpets (including designing/making plate) Make and fit throttle cable and pedal linkage. Fit pedal box assembly and make/fit foot plate Add loom and plumbing fixings Remove exhaust manifold and fit remaining ancillaries to engine Supply and fit additional sensors to engine (coolant temp, oil temp, oil pressure, fuel pressure, air temp, Lambda, airbox pressure). Modify and fit fit hydraulic handbrake Replace clutch slave cylinder Fit OEM handbrake cables and ensure operation Commission brake system including bleeding. Commission engine system for initial running. Run in engine Oil change and post dyno check Corner Weight Geometry setup A few pictures of progress. Temporary air filter for start up and mapping, cold air intake to come later.... I'm currently taking HRT ~ Hachi Roku Therapy |
12-11-2013, 09:53 AM
Post: #404
Sweet!
12-11-2013, 06:29 PM
Post: #405
One hella serious build going on here!
I only think its weird that so many people run airbox on ITB engines when open filters are proven to perform better, but then again the one good thing my car has is irrelevant when your complete car is so much tidier and better put together, so nvm really Keep us posted 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
12-11-2013, 08:58 PM
Post: #406
Far from it buddy, the volume of that air box has been proved to be much more efficient than open trumpets. Glenn who designed it has been tuning beams engines for years has played with various volumes and found what's optimal.
12-11-2013, 11:11 PM
Post: #407
Oh, beams!
Clearly I was not thinking straight! Even so I thought open stacks was "teh shiz", just goes to show my, as usual, unprecedented numbnuttery! Apologies, and again that is one hella car 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
12-12-2013, 01:55 PM
Post: #408
Where do I get an air box like that for my 4AGE? It looks awesome!
12-12-2013, 11:30 PM
Post: #409
Jan Pedersen Wrote:Where do I get an air box like that for my 4AGE? It looks awesome! Not sure mate, I don't know if this would fit a 4AG engine, message Glenn on here CelicaRA_45 I think. I'm currently taking HRT ~ Hachi Roku Therapy |
12-16-2013, 03:42 PM
Post: #410
Jan Pedersen Wrote:Where do I get an air box like that for my 4AGE? It looks awesome! http://page8.auctions.yahoo.co.jp/jp/auction/h180594989 |
ae86 racecar with beams engine | bakonick | 148 | 164,149 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 89,077 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 736,476 |
Beams Levin build | mannix20vt | 5 | 9,305 |
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 88,675 |
