AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
01-29-2017, 06:49 PM
(This post was last modified: 01-29-2017 06:53 PM by Conrad.)
Post: #451
So the car went on a little journey, time to get the exhaust system issue rectified.
Manifold downpipes shortened and the entire system lifted up. The rear section has now been re-routed over the axle. I'm currently taking HRT ~ Hachi Roku Therapy |
01-30-2017, 04:11 AM
Post: #452
This is excellent... Awesome decision man...
Sent from my HTC_0P6B using Tapatalk clutch kick, switch, tree .... oowwww |
05-22-2017, 08:05 PM
Post: #453
Sorry, I am suffering from a lack of interest at the moment.
A few bits done.... The list is getting smaller: Fabricate heel plate for driver to suit pedal box. Completed Fabricate and fit breather tank for the cam cover vents. Completed Wire up the wiper motor and configure PDM, function test. Completed Fit wiper arm and new wiper blade. Completed Wire up indicators to work from indicator stalk as well as the console switch. Completed Fit TRD anti-roll bar. (Now bought the required parts) Fit Roll cage protection on door bars.(Partially) Fit Takata Harnesses. No MOT No Magazine Photoshoot. No Finished ! No I'm currently taking HRT ~ Hachi Roku Therapy |
05-23-2017, 02:25 PM
Post: #454
One of the last jobs to do is fit the rear TRD anti-roll bar. All the mounting fixtures were missing from the fabricator so I took the opportunity to get some Techno Toy Tuning items to enhance the set-up and give plenty of adjustment in the set-up.
TTT T3 Parts TRD Anti-Roll Bar (ARB or Sway bar in some countries) Car jacked up and put on the ramps to make a start Drop link mounting blocks bolted onto the chassis rails... I'm currently taking HRT ~ Hachi Roku Therapy |
05-25-2017, 09:27 PM
Post: #455
ARB lowering mounts on and the ARB mounted up
Drop links mounted And finished.... I'm currently taking HRT ~ Hachi Roku Therapy |
05-25-2017, 09:54 PM
Post: #456
looks good, though I would advise to mount it on the softest setting rather than the mid one. You can't get enough traction at the rear. My friend removed the rear ARB alltogether on his hillclimbing race car
Sent from my SM-T800 using Tapatalk AE86 ex-daily |
05-25-2017, 10:21 PM
(This post was last modified: 05-26-2017 03:46 PM by Conrad.)
Post: #457
Fabricate heel plate for driver to suit pedal box. Completed Fabricate and fit breather tank for the cam cover vents. Completed Wire up the wiper motor and configure PDM, function test. Completed Wire up indicators to work from indicator stalk as well as the console switch. Completed Fit T3 ARB parts and TRD anti-roll bar (Now bought the required parts). Completed Fit wiper arm and wiper blade. Fit airbox snorkel and filter. Fit Roll cage protection on door bars. (ongoing) Fit Harnesses. MOT Magazine Photoshoot I'm currently taking HRT ~ Hachi Roku Therapy |
05-26-2017, 03:58 PM
Post: #458
More work done.....
Fit wiper arm and wiper blade. Completed Fit Harnesses. Completed Single Wiper arm fitted Takata Harnesses installed You can also see a bit of the carbon firbre roll cage protection in this picture. Remaining jobs.... Fit airbox snorkel and filter. Fit Roll cage protection on door bars. (ongoing) MOT Magazine Photoshoot I'm currently taking HRT ~ Hachi Roku Therapy |
05-26-2017, 11:35 PM
Post: #459
3 things, first of all great work as always. Regarding the wiper I would orient it facing straight up (think old mercs) and last but definately not least, you are missing one very crucial point on your to do list: drive the bloody car
06-12-2017, 06:46 PM
Post: #460
(05-26-2017 11:35 PM)Bean Wrote: 3 things, first of all great work as always. Regarding the wiper I would orient it facing straight up (think old mercs) and last but definately not least, you are missing one very crucial point on your to do list: drive the bloody car Bean, Regarding the wiper, I tried that but it came over to far on the drivers side, with its current position I get full sweep to the edge of the screen I'm currently taking HRT ~ Hachi Roku Therapy |
ae86 racecar with beams engine | bakonick | 148 | 165,223 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 89,582 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 740,686 |
Beams Levin build | mannix20vt | 5 | 9,355 |
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 88,943 |
