AE86 Injector sizes
08-08-2011, 10:29 PM
AE86 Injector sizes
my 4age was a highcomp. map version
@ bean bandit: now i'm going to use supra 7mge (n/a) injectors 312cc high imp. they are straight fit in the ae86 fuell rail and head '87 levin coupé |
08-09-2011, 09:08 AM
AE86 Injector sizes
Bean Bandit Wrote:Uzelac Wrote:Now i use 295cc injectors from Porsche 944 2.5 N/A. I believe that's good size for modified NA 4AGE with ITB's. They are low impedance and not a straight fit. Although, it was very easy to modify them on lathe. Stock head, stock fuel rail and FRP. And they are grey |
08-09-2011, 07:50 PM
AE86 Injector sizes
taken from another forum;
early bigport 4age's are 220cc @ 48psi (blue top), low ohm later bigport 4age's are like 240cc @ 48psi (tan), low ohm smallport 4age's are 250cc @ 48psi, high ohm silvertop and blacktop use the same (side feed) are 270cc @ 48psi, high ohm 4agze is reddish and 365cc @ 48psi The bigport injectors are bigger than I thought! :S |
08-12-2011, 12:10 PM
AE86 Injector sizes
Bigger ?
High reving 1.6 engine like 4AGE should use way above 200cc. |
08-12-2011, 05:15 PM
AE86 Injector sizes
Stock starlet gt/glanza (4efte) injectors are 295cc high imp. (Just for reference). No mods needed to fit.
Japan 4 Ever |
08-12-2011, 07:59 PM
AE86 Injector sizes
The bleu injectors from your swiss MAF Hachi are 210cc low-imp injectors.
On the bleutop you also ave the grey like the one that patrik show us and it's are 182cc low-imp On the redtop Map you can have pink one that are 200cc low-imp On the redtop hi-comp (small port) it's are green and are 250cc hi-imp SR Team BURN THE RUBER NOT YOUR SOUL! |
08-12-2011, 11:06 PM
AE86 Injector sizes
Huh.. could be.
I allways found info of ~185cc so i concluded mine blue are that size. Could be that they are bigger. btw. what is default fuel pressure. around 2.7 bar, 36psi ? |
08-13-2011, 01:10 AM
AE86 Injector sizes | |||
08-13-2011, 02:40 PM
AE86 Injector sizes
Thanks for the help, Just need to find a set now
Injector voltage problem [fixed] | d3nso | 16 | 18,527 |
04-03-2016 12:39 PM Last Post: d3nso |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,901 |
02-20-2016 11:48 AM Last Post: Bean |
Injector sizes info | ZaX | 19 | 36,421 |
07-17-2013 01:54 AM Last Post: jondee86 |
pink injector resistance | Apsogos | 2 | 4,063 |
10-01-2012 09:00 AM Last Post: Ivan141 |
Question regarding wheel sizes? | heshan | 3 | 4,369 |
05-21-2012 09:22 PM Last Post: Saber |
