AE86 Rear Brake Upgrade - Caliper & Discs?
05-16-2008, 06:39 AM
My supports for Brembo clamp are ready
To see the assembly, to go on this topic
http://www.aeu86.org/viewtopic/ae86/t/32...c/start=25
I am to occupy to see whether I can make them less expensive.
For the moment it return has 220€.
[Image: AEU86 AE86 - AE86 Rear Brake Upgrade - C...mp; Discs?]
Toyota Team Europe Forum
my old 86: http://www.aeu86.org/viewtopic/ae-86-fro...ght=#46541
05-16-2008, 10:55 AM
Hi Seb,
You might consider opening a new thread for this, that should provide a better focus on what you are doing. i'm sure many members are interested.
Also, you could consider contacting one of our members regarding the production of brake supports/adapter plates. Just search for "Aussiefan". He was already able to offer the FC adapter plates for a very reasonable price, and I believe that people were happy with the service and quality.
05-17-2008, 12:13 AM
[quote="seb"]I prepare a kit of front conversion with discs of 276 mm and caliper Brembo 4 pistons.
The assembly will be Bolt on.
damn thats bigger than the flywheel. 276mm!! are you sure its that big?
te72 wagon
ae86 levin coupe project
05-17-2008, 12:24 AM
Peddle boxes will be a must here guys, loads of options from the rally guys over here.
05-25-2008, 03:06 PM
The original disc are 234 mm mini disc are 276 mm.So is greater. Big Grin
I do some test, and the compromise is really interesting. The master cylinder am quite.
The braking is effective and enduring. A very good progressive mix. A super feeling! Thumbs up!
06-11-2008, 02:46 PM
Hello Everyone!
The VW Golf IV calipers must be from the front or from the rear axle? I also would like to know which engine version is ok? There were a wide range from the 1.4 to the R32.. Any info and help is welcome.
Thank you in advance.
TeZe
jamiemirror Wrote:Already discussed, VW calipers + Nissan discs= 257mm rear (almost bolt-on) upgrade for cheap !
06-16-2008, 11:01 AM
Yes.
There is no R32 in scrapyards, any other rear caliper will work.
08-07-2009, 01:36 PM
hi guys ive just installed the MA45 MA46 MA47 rear end in my ke70 thats im currently building. the standard rotors are fine atm but that prob we have here in new zealand is that u cant buy them new anymore and very hard to find even used 1s. are they stil able to be purchased new in other countrys?
also i see r32 skyline brakes being mentioned. there are plenty of them over here. they wouldnt be a direct replacement ? or is there anything that is a direct replacement without havin to change calipers?
thanks for any help Smile
  Handbrake adjustment discs? DMC 8 1,701 03-10-2024 08:08 PM
Last Post: DMC
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 5,676 06-23-2017 05:21 PM
Last Post: pack
  Rear Caliper Rebuild mad.matt 16 16,714 01-19-2017 02:19 PM
Last Post: Project D
  AE86 Rear Brake options. hachirokuGTV 66 122,077 08-27-2016 11:01 PM
Last Post: izanagi
  Ta60 carina steering upgrade? Allexz 15 15,194 06-01-2016 08:12 AM
Last Post: Allexz
