AE86 Rear Brake options.
01-11-2008, 06:47 PM
Must be hard to find now I think
Filh Filh Save the RWD cars |
01-11-2008, 11:02 PM
If you all ask jamiemirror nicely he might post those pics and specs.
01-12-2008, 12:05 AM
we didn't get the MA45 in europe, so that's a big nono for parts finding
01-12-2008, 04:48 PM
No need for "nicely asking", a small "tragedy" (broken digital camera, must make pics again with the GSM phone camera ....
01-13-2008, 03:01 AM
here is a pic of my setup MA45 celica , direct bolt on backing plates, calipers, and cables,
Here is a ae86 and MA45 rotor side by side There are still a few of these cars around in NZ |
01-13-2008, 07:17 AM
Is that MA45 disc 250mm + ?
Another convo nearly the same size as S13 258mm , S13 rear discs fit the JDM diffs with center locator fitted and the caliper spaced out to suit the diameter difference. Other options are corona 280mm complete with the internal alloy hand brake backing plates and girlock caliper. Fitted to T series t18 or ra60 diff housing. Alot lighter set up than any steel mounting ae86 rear set up. also 910 bluebird is nearly the same brake package as the corona with alloy caliper and backing plate. both corona and bluebird depending on caliper use the same pad and caliper , also the same as holden commordore in aus. if going five stud you can use the S15 disc with S13 caliper or maybe with spacer ae86 calipers. This set up also still fits inside 15" rims and maybe a few 14". Just don't expect the small pad area of those calipers to really handle track use for more than a few laps. z32 or r32 rear only fits inside 16" rims but done with all alloy parts makes for a big disc 280x22mm and twin piston caliper with the weight of the other set ups |
01-13-2008, 07:30 AM
I'd swear blind that the S2000 AE86 featured in the Best Motoring video used discs all round from an RX7, all under 15" wheels.
Ignore me if that's wrong or useless. English dude in NZ. Photographer. Noob. Tall. |
01-13-2008, 11:46 AM
I have changed the rear axle with an rear axe of a Toyota Carinna....but this one doesn't have disc brakes(
Someone can tell me where i can find the original rear axle or one that might fit ? daily driver Toyota Corolla 1986 |
01-13-2008, 10:16 PM
brawnie Wrote:I have changed the rear axle with an rear axe of a Toyota Carinna....but this one doesn't have disc brakes( I would check the build plate of the carina , from memory mostly there are T series ie: t292 code etc |
01-15-2008, 08:43 PM
very interesting
Toyota Team Europe Forum my old 86: http://www.aeu86.org/viewtopic/ae-86-fro...ght=#46541 |
ITB filter options | mister86 | 1 | 3,348 |
12-06-2020 10:44 AM Last Post: Bean |
AE86 starter options | max_ae86 | 12 | 29,647 |
07-28-2019 08:17 PM Last Post: harkes |
AE86 rear suspension options 2018 | Alex | 9 | 10,649 |
01-24-2018 02:25 PM Last Post: mad.matt |
Rear axle options | Dino86 | 13 | 12,747 |
Gearbox and Diff options | MIGGZFSU | 35 | 27,500 |
03-26-2017 12:00 AM Last Post: MIGGZFSU |
