AE86+SR20
05-07-2010, 05:38 PM
AE86+SR20
I have only seen it done once. I have a 240sx with a sr20 dropped in it, plus stage 3 clutch. The bad part is, being Me... I pushed it a little to far... As in hit a tree.. The engine is still good but the body is TRASH and frame is bent. So I have a really good engine but no car. So I was looking into putting the sr20 into a ae86. I have no idea how much it going to cost or how I'm going to fit it in there. So If any of you have any idea or anything like that it would be awesome to give me some info.
05-07-2010, 05:48 PM
AE86+SR20
i see its your first post, welcome to the forum
you can ask "jasper" he is the owner of a ae86 with a sr20.
daily driver avensis 2.0 d4d and Yaris 1.0
weekend driver 1985 AE86
05-07-2010, 05:55 PM
AE86+SR20
How does one find this so called "jasper"?
05-07-2010, 06:12 PM
AE86+SR20
You get 3 guesses..
Tongue Smile
05-07-2010, 06:16 PM
AE86+SR20
Basically you are going need custom motor mounts , trans mount, fire wall and trans tunnel modification depending on your oil pan you may need to modify the cross member, custom header, wiring, ect. ect.
05-07-2010, 06:22 PM
AE86+SR20
..... GOOGLE... or the search bar
05-07-2010, 07:13 PM
AE86+SR20
Do a search on the forums for sr20det. You'll find at least two results: Zax and Jasper. Probably some others too. They know the most about the swap. The australian forums are also ridden with hybrid ae86s so take a look over there too.
05-07-2010, 08:37 PM
AE86+SR20
Can try for SR86 also, that combo is so common that people gave it a standard name Smile
p.s. often, they also transfer whole suspension from S13
05-08-2010, 03:41 AM
AE86+SR20
Just wondering.. how much HP can you get out of a stock ae86 motor>?
05-08-2010, 04:58 AM
AE86+SR20
Rusticmeattank Wrote:Just wondering.. how much HP can you get out of a stock ae86 motor>?
A friend of mine is knocking on 500WHP out of his in an AW11.
  SR20+AE86 red_drifter 4 6,893 04-15-2009 04:41 PM
Last Post: pedro-siR
