AE86 slow on the revs and hesitant.
06-17-2012, 10:55 PM
Hello!
Just got my AE86 back together and on the road, unfortunately the engine won't run properly I've reset the ignition timing correctly 2 times as I first thought this was the problem. At 10 BTDC the car is barely driveable, you have to rev it hard and release the clutch slowly. Currently I'm running 15 BTDC and the car is driveable but slow revs and throttle response and hesitant on acceleration. It drove wonderful last year before it went i the garage. Only things I've done to the engine over the winter is: Rebuilt alternator and dizzy (why I thought it might be a ignition problem) New airfilter New oilcooler Removed the viscous fan Changed all the pullies to light weight Other mods to the engine is TRD cams 272º 7,5mm TRD Pistons TRD 0,8mm gasket Stainless header and exhaust I'm really lost on what to do next. Buy new Sparkplugs, wires and dizzy cap? I'm thinking of doing a compression test on it aslo. // Johan |
06-18-2012, 07:45 AM
I can't make it up clearly from your post but did you change the pistons and the headgasket etc as well over the winter? or only the alternator, dizzy etc?
AE86 Levin |
06-18-2012, 01:13 PM
It is possible to put the distributor drive back onto its shaft 180 degrees out after you have rebuilt the distributor.
You mention light weight pulleys ? If you have not changed the crank pulley then it would be a good idea to check the TDC reference is correct, the outer rim has a habit of turning independantly of the inner part. When this happens your TDC marks also move and your ignition timing will be out even though it appears to be at 10 degrees when timed with a light. An analogue brain in a digital World |
06-18-2012, 09:20 PM
bozu Wrote:I can't make it up clearly from your post but did you change the pistons and the headgasket etc as well over the winter? or only the alternator, dizzy etc? Only the alternator, dizzy etc. totta Crolla Wrote:It is possible to put the distributor drive back onto its shaft 180 degrees out after you have rebuilt the distributor. Hmm, how do you check if the drive is in the correct place? The crank pulley has been changed as well. |
06-19-2012, 09:35 AM
Ordinarily you could do the following things to make sure everything is set correctly @ TDC:
-Set crankpulley to 0 deg mark -Check for dimple in camshaft under oil filler cap (not an option on aftermarket stuff probably). -Take out nr1 sparkplug, use a long screwdriver or whatever and feel if the nr1 piston is really at TDC. -Take out distributor @ top dead center. If you have it in correctly, there should be a line on the shaft that lines up to a dimple on the body directly above the shaft on the distributor ( or was it vice versa, anyhow you get the point). -When you're sure piston nr1 is really at TDC, check campulley positions. FABRICA MI DIEM, PVNC! |
06-19-2012, 09:40 AM
What's the compression?
Set the timing so it runs well, high fast smooth idle. Forget the timing light, toss it except for checking that the advance works & passing emissions! Advance it until it only pings/detonates when abused, with the octane of your choice. ** ** ** Advance is the ignition advance, 10-15 at idle, going up to 30 @3000rpm or there abouts, that's what really counts The advance with the diagnostic plug means nothing at all, except for the diagnostic plug. I wouldn't care a bit about it. So what! |
06-19-2012, 11:02 PM
Ivan141 Wrote:Ordinarily you could do the following things to make sure everything is set correctly @ TDC: All three marks are where they're supposed to be when the piston is at TDC. I will remove the distributor and check how it lines up. allencr Wrote:What's the compression? As it is now it idles at ~800-900RPM when hot. Now that you mention it, I'm not really sure the car advances the timing when the diagnostic is pulled out and emissions is not really anything I need to worry about, I'm allowed to have 4,5 CO . Don't have any chance to get a compression test done until 2 weeks or so Another thing that I thought of but it seems like a real long shot or maybe abit retarded is that the oil is to thick? ![]() So my to-do list for Sunday so far (only chance I have to work on the car this week) is: 1. Check that the distributor lines up. 2. Try and advance the timing some more but 15 degrees BTDC seems really high already. 3. Spray startergas around the intake and vaccum hoses to check for leaks. 4. Some injectorcleaner? 5. ??? Thanks for all your help so far! ![]() // Johan |
06-20-2012, 12:03 AM
if your car doesn't go into diagnostic mode (search the forum, plenty of threads explaining it in detail) the timing needs to be set at 16° BTDC when warm (@~800rpm)
for the oil to be too thick to get your symptoms the bearings would have seized long ago
AE86 ex-daily |
06-20-2012, 12:09 AM
2 pretty obvious things:
Have you checked for diagnosis codes on the dashlight? Does your car go into diagnosis mode as soon as you shortcut the terminals? (idle drop, changing the timing, flashing light on dashbord) Checked the cambelt? Did you dial in the cams in according to the spec sheet? I had it once wrong by one tooth exhaust cam and the throttle response was awfull so was the poweroutput. Don´t think there are any air leaks cause the idle is perfect. I also doubt its fuelrelated, but an injection clean doesn´t hurt ![]() No chance its the thick oil! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
06-20-2012, 08:55 PM
Did you check if piston 1 was @TDC physically? It's not unimaginable to get this wrong when changing pulleys. The crank spins twice for every turn of a camshaft.. so there is the possibility of getting things wrong when reassembling.
Oh and another check, you'll think I'm insulting you but I got this wrong myself once: You sure you got the order of your sparkplug wires correct? You're symptoms sound mighty familiar.... FABRICA MI DIEM, PVNC! |
| Engine starts/revs but no idle | GenkiMotors | 17 | 12,629 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
| Slow tachometer problem. LHD AE86. | Arima-kun | 2 | 6,063 |
06-22-2014 11:17 PM Last Post: Arima-kun |
| Engine revs up/down on its own | El_Camino | 8 | 17,150 |
04-27-2014 05:49 PM Last Post: Apsogos |
| Revs going up and down... | Okami | 8 | 11,454 |
06-28-2012 07:25 PM Last Post: Okami |
