AE86 slow on the revs and hesitant.
06-22-2012, 12:09 AM
First of all, thanks for your replies guys!
![]() Secondly I need to clear up some things as I've been far to much in my own head when trying to explain things for you. I've physically checked that the #1 piston is at TDC when the crank pullie, cam gears and cam dimple line up as they should. When I wrote pullies what I meant was: Crank, alternator and water pump pullies. I haven't touched the cams, intake or anything mayor on the engine except the distributor, which is why I assumed that it must be a ignition problem but since I've set it where it should be and the car still runs like a piece of crap it "must" be something else? Checked again and the car does enter diagnostic mode but the only change is that the "check engine" light starts to flash, no directly noticeable change to idle or timing. The light flashes 11 times which I found out through some googleing means that there's something wrong with the AC which I don't have. The connections on the distributor cap has 1,2,3,4 molded in so I've put the respective cables on the corresponding number. I've also ordered new sparkplugs, cables, distributor cap and rotor arm. Hopefully I will get them on friday so I can change it on sunday to see if it makes any changes. And the oil thing was just something I got in my head and started to over-think ![]() Thanks for all your help again! ![]() // Johan |
06-22-2012, 01:18 AM
krullibull Wrote:First of all, thanks for your replies guys! Your car isn´t going into diagnosis mode. Check again, Code 11 A/C switch and idle switch. Obviously you don´t have aircon, but if your idle switch is not closed your engine won't go into diagnosis mode and it will be impossible to set the timing right, had it before on mine, it drove like sh** ![]() Set up the TPS (Throttle position senseor) to the manual specs, all you need is a feeler gauge and a multimeter. Almost 100% sure this should cure the problem and you should be able to set the timing right. An old post covering the problem: http://www.aeu86.org/viewtopic/4age-igni...ght=timing 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
07-16-2012, 05:07 PM
Sorry that I took so long to reply.
Thanks to the tips I got from you guys I was able to get it running as is should ![]() All I had to do was: Setup the TPS. Change direction on the distributor drive gear. Solder two cables which was on the verge of braking on the yellow plug from the distributor. Change the sparkplugs, cables, rotor and distributor cap (not sure that this made any difference but it's nice with new stuff ![]() So now I can go on my first driftday this weekend ![]() Thanks again for all your help! ![]() // Johan |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,822 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
Slow tachometer problem. LHD AE86. | Arima-kun | 2 | 4,997 |
06-22-2014 11:17 PM Last Post: Arima-kun |
Engine revs up/down on its own | El_Camino | 8 | 14,342 |
04-27-2014 05:49 PM Last Post: Apsogos |
Revs going up and down... | Okami | 8 | 9,347 |
06-28-2012 07:25 PM Last Post: Okami |
