AE86 wheels
06-01-2005, 11:01 AM
Post: #101
AE86 wheels
i know, i would like to use those siezes, but i cant afford to buy any rims right now. so ill have to stick with 13s.. so what tyre size to use with?
5.5x13 (stock) 6.5or 7x13 (widened) tnx! |
06-01-2005, 11:04 AM
Post: #102
AE86 wheels
Apolan Wrote:i know, i would like to use those siezes, but i cant afford to buy any rims right now. so ill have to stick with 13s.. so what tyre size to use with? 185/60/13" stock (up to 195/60 - don't use 50 or 55 profile for 195 with 5.5J rims!) 185/60/13" - 205/50/13" range |
06-01-2005, 11:24 AM
Post: #103
AE86 wheels
185/60 13 than? but doesnt that make the wheel diameter smaller in all? so the speedo would be off, and also i would get much shorter gears?
thank you for your help! |
06-01-2005, 11:32 AM
Post: #104
AE86 wheels
Quote:185/60 13 than? but doesnt that make the wheel diameter smaller in all? so the speedo would be off, and also i would get much shorter gears? Yes. A little bit (6.7%): http://www.aeu86.org/viewtopic.php?p=18892#18892 |
06-01-2005, 11:38 AM
Post: #105
AE86 wheels
so is this recomendable?
06-01-2005, 11:46 AM
Post: #106
AE86 wheels
Apolan Wrote:so is this recomendable?It will work good (you will notice difference but there is no reason to worry). I ride AE86 on 185/70/13" and these tires seems little slippery on high-speed turns on the highway - I think "60" ones will perform better. PS: Now I try to change to Supra wheels and I hope to improve high-speed stability of the car. |
06-01-2005, 11:56 AM
Post: #107
AE86 wheels
yes i will be looking for some 14x7 too later on. now ill just have to go with 13'. great, tnx for all the help.
greets! |
06-01-2005, 08:50 PM
Post: #108
AE86 wheels
i have 4 Mile Miglia 6X14 for sale but the problem i think is the shipping...
AE86 FANATIC!!! |
06-02-2005, 08:42 AM
Post: #109
AE86 wheels
jamiemirror Wrote:Quote:185/60 13 than? but doesnt that make the wheel diameter smaller in all? so the speedo would be off, and also i would get much shorter gears? I did some calculations and i came out w/ 16,7% not 6,7%. dont you think its a bit too much? |
06-02-2005, 11:39 AM
Post: #110
AE86 wheels
Quote:I did some calculations and i came out w/ 16,7% not 6,7%. dont you think its a bit too much? 16.7% is very big difference. I think that your calculations may be wrong :-) |
