Front fender (wing)
02-09-2008, 08:59 PM
Front fender (wing)
I need to remove the front fender from my car, can someone who has done it before give me a few tips.
It looks fairly straightforward but I'm not sure what holds it on at the bottom.
Thanks
02-09-2008, 09:09 PM
Front fender (wing)
Front wing???
Remove the front indicator (screwdriver), undo the line of 10mm bolts along the top of the wing in the enginebay, theres 2 beside the door hinges, be careful not to remove paint off the door, & there are 2 behind the arch on the sill which usually break off once disturbed
02-09-2008, 09:40 PM
Front fender (wing)
Thankyou for a quick reply.
If the two break off what are the re-fitting options ?
02-09-2008, 09:54 PM
Front fender (wing)
See how you get on, If the wing is rotten but the sill is good its not so bad, Ive even bonded the wing onto this area before.
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,142 03-05-2023 09:34 PM
  Converting Jap Spec wing mirrors to UK spec chrisae86 5 2,274 04-12-2022 11:03 PM
Last Post: chrisae86
  GT Wing options 4000GT 10 20,769 06-19-2014 07:34 AM
Last Post: 4000GT
  Question: Where I can find this fender flare? winchi.c 3 5,213 05-01-2011 09:58 AM
Last Post: Bentley
  fender holes measure HELP sergiocharged 11 11,051 12-24-2010 04:08 PM
Last Post: aussiefan
