AE92 front shocks
02-13-2005, 01:46 AM
AE92 front shocks
Anyone got pics on how low the car sits when using the shorter ae92 front shocks?
Broken down 1984 Trueno HB |
02-13-2005, 03:03 AM
AE92 front shocks
I think i read somewhere that they lower about 40 mm.
You could always photoshop it! |
02-13-2005, 11:22 AM
AE92 front shocks
I dont think it gets any lower just by using ae92 shocks...
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
02-13-2005, 11:54 AM
AE92 front shocks
Jan it does and it doesn't
Just putting in ae92 shocks will give you no lowering at all, but you will have a major problem because the shocks are not long enough to be used with stock springs. It's the springs that define how low your car sits. Important is that your shocks match your springs. Take stock springs and the ae92 shocks that the shocks will just be hanging inside the strut case. The proper install is to shorten the struts and use different springs, preferably something adjustable so you can fine tune it. You need to shorten the struts, the ae92 shocks are 6 or 7 cm shorter then the ae86 ones, most people shorten the struts by 4cm and fill up the remaining space with spacers so the shock nicely fits inside the shortened strut. Then you can finetune it all. You have to think this out carefully though because if you make your car to low by setting your springs to low (assuming you went adjustable) or when you position them to high, then your shock wont work in its optimal range. This is a very very good read on the subject: http://www.club4ag.com/faq%20and%20tech_...ersion.htm Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
02-13-2005, 11:56 AM
AE92 front shocks
Aico Wrote:Anyone got pics on how low the car sits when using the shorter ae92 front shocks? Search pics of my car with coilovers. -> http://www.aeu86.org/viewtopic.php?t=119 Drifting - best fun you can have in your car with your pants on! |
02-13-2005, 11:58 AM
AE92 front shocks
Owh,just to complete the story, if you get lowering springs, or adjustables, but you keep the ae86 shocks, you will run out of movement for the shocks. Thats the whole reason you need to shorten your struts which means ae86 shocks no longer fit so you need to install ae92 shocks.
So shocks dont lower your car, but different shocks are needed to lower your car. And most important, if you go with a lowered hachi, RCAs are a must or your handling will be crap. Aico, why don't you buy the T3 coilover kit? Sure costs a bit of money but you know that you have the best kit available for the hachi. Other alternative would be getting ae92 shocks and the coilover set by paradise racing and follow the instructions in that link of my previous post. But I doubt it will be better then T3s setup unless you have years of experience knowing what you are doing. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
02-13-2005, 01:28 PM
AE92 front shocks
haha, damn i was wrong. I blame the late hour.
02-13-2005, 03:01 PM
AE92 front shocks
Quote:Just putting in ae92 shocks will give you no lowering at all, but you will have a major problem because the shocks are not long enough to be used with stock springs.Thats the long version, Mux I was just too lazy to explain myself at that time Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 3,401 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 20,788 |
Question about KONI shocks for an AE92 | Apsogos | 1 | 4,126 |
09-13-2013 07:40 AM Last Post: Apsogos |
ae92 external thermostat housing plumbing? | danny 86 | 2 | 5,104 |
08-15-2013 12:38 AM Last Post: fax0815 |
Annoying sound (Ae92 hatch gti) | Apsogos | 2 | 4,489 |
01-02-2013 12:13 PM Last Post: Apsogos |
