Aram's 3SGE Beams Levin Coupe
03-16-2010, 05:52 PM
Post: #71
jesus aram! im surprised you drove your daily around like that!
Brake with the left hand, steer with the right foot... |
03-16-2010, 06:35 PM
Post: #72
Livin' on the edge!!!!!
03-17-2010, 12:14 AM
Post: #73
btw... does anybody know what these cars use to get the sparks? they have some kind of metal slider underneath... |
03-27-2010, 06:29 PM
Post: #74
So I fixed the shock problem, I swapped it with one from the project car.
And today we finaly turned the car on it's side, now the beams under the trunk can be fixed. After this it's going on the grill. Should have update pics later this week!! |
03-27-2010, 07:29 PM
Post: #75
I think that fender flare should be turned a little bit rear...
You should measure where is a centerpoint on the flare and a rear arch, then put it on right place. "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
04-30-2010, 02:52 PM
Post: #76
Yes, good point, this one is coming off, and I will be there when we fix the new one.
This time we will have the new wheels too! Just got them on Teusday, tires are here the 6th. Check the difference in white between the wheel and the car hahaha. |
06-12-2010, 08:51 PM
Post: #77
Alright, a small update.
Wheels on the car: Also received my digidash. Then we started on the rear arches. I was not satisfied with first attempt so I was present this time. So now they are on to my taste. The Ford fenders are about 1.5 cm wider then standard I think. The wheel under the car in the next pic have a 20mm spacer. They are about 10mm too wide so I need 10mm spacers. I think it will look great actually. First steps: And welded on: |
06-13-2010, 10:12 AM
Post: #78
Well done guys, brilliant work, Keeping the ae86 alive indeed
06-13-2010, 10:56 AM
Post: #79
Thanks m8, it's nice to create something alive again from a wreck indeed.
06-13-2010, 05:45 PM
Post: #80
nice work you have done so far,that was much rust you have found..
what size/brand of wheels is that where did you find those??local or.. daily driver avensis 2.0 d4d and Yaris 1.0 weekend driver 1985 AE86 |
ae86 racecar with beams engine | bakonick | 148 | 161,049 |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 86,712 |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 14,403 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 157,690 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 599,209 |
User(s) browsing this thread: 15 Guest(s)
