Back-Up (reverse) lights problem
12-27-2009, 05:06 PM
Hi guys,
My back-up/reverse lights not working anymore. My rear/turn/brake lights worked like normal. Where should I check? I think the back-up/reverse lights does not have apart fuse right? Or maybe the switch right under the car defect? Thanks in advance. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
12-27-2009, 08:08 PM
Check the connection between the rear light switch and the cable on the transmisson
It usually becomes loose
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
12-27-2009, 08:13 PM
[Walaki]D`Lair Wrote:Check the connection between the rear light switch and the cable on the transmisson the switch are under the car right? 1985 AE86 (ハチロク) Levin - Summer time daily driver |
12-27-2009, 10:18 PM
yes, on the left side of the tranny
12-27-2009, 10:20 PM
thanks
will check it 1985 AE86 (ハチロク) Levin - Summer time daily driver |
| Can you convert your 86 back too the original state? | gh0st | 7 | 5,577 |
| Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 13,494 |
12-19-2021 11:58 PM Last Post: gh0st |
| back camber of CBY | roiz86 | 5 | 11,108 |
03-24-2013 02:00 PM Last Post: roiz86 |
| 4agZe problem solved - 99% IC problem | Okami | 41 | 45,266 |
07-12-2012 04:49 PM Last Post: Okami |
| Reverse gear selector wiring... | 4000GT | 5 | 9,026 |
08-28-2011 04:58 AM Last Post: 4000GT |
