Ball joint removal with arm attached??
05-06-2010, 03:42 AM
What is the best way to remove the ball joints without unbolting the control arm?
05-06-2010, 04:08 AM
I wouldnt think it possible. It needs to be pressed out.
05-06-2010, 04:44 AM
I saw this, not sure if it would work on the corolla http://www.youtube.com/watch?v=ISY8bGof3bQ
I guess it is not a big deal to remove the arm. Should do the bushings anyway. |
Rear arm length | totta Crolla | 7 | 702 |
06-05-2024 08:53 AM Last Post: totta Crolla |
Power Steering Removal | 20valver | 2 | 593 |
4AGE cylinder head plug removal | Ivan141 | 5 | 1,812 |
Sill removal | totta Crolla | 3 | 1,763 |
09-14-2022 06:30 PM Last Post: totta Crolla |
Lower arm hits toe arm on lock... | fullybuiltmiata | 12 | 13,054 |
01-14-2016 11:52 PM Last Post: Deuce Cam |
