Banpeis project
04-12-2006, 06:53 PM
Post: #221
Banpeis project
I've finally bought a decent camera: so now I can take normal pictures
![]() I also found another place where the boot is leaking. So need to fix that as well... ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
04-13-2006, 07:39 AM
Post: #222
Banpeis project
BTW banpei, you mentioned somethin about a cutout from a wrecked hachi that was going to be used to fix that right rear panel of yours. Was that thing cut from the car in amsterdam? I need a piece of that panel (the bit behind the right rear light cluster), and need to know if it's still on the car before I go and try to get it.
04-13-2006, 09:36 PM
Post: #223
Banpeis project
Ivan141 Wrote:BTW banpei, you mentioned somethin about a cutout from a wrecked hachi that was going to be used to fix that right rear panel of yours. Was that thing cut from the car in amsterdam? I need a piece of that panel (the bit behind the right rear light cluster), and need to know if it's still on the car before I go and try to get it.I couldn't use that part since the fenders are a bit too rusted away. ![]() So I probably will go for either custom job or remade Startlet (P7 I thought) fenders. Anyway, about your question: as far as I can remember the boot of the car was in okay condition compared to the rest of the car and still had the rubber on it. But I'm not too sure about that. I don't think I'll go back to that wecker for a while so maybe Robokill can check it out if he has the time. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
04-14-2006, 12:47 AM
Post: #224
Banpeis project
Banpei i am gonne ask the wrecker for the wreck :-) with everything left in it :-D
04-14-2006, 07:40 AM
Post: #225
Banpeis project
Not going to happen...Jasper already tried that I think..
05-15-2006, 10:27 PM
Post: #226
Banpeis project
Made some pretty pictures yesterday.
05-20-2006, 10:17 PM
Post: #227
Banpeis project
Today Mux and I fixed some things on our cars. Mux replaced his stock breaklines with steel-breaklines.
![]() I replaced the slave cylinder of my clutch (was leaking), removed the heat-harness around the exaust (rattling) and did some small stuff. Fortunetly I did bring along my camera, however it is not the camera I like to bring along when fixing cars. ![]() Oh, and the white-balance is off since I forgot to remove the custom white-balance when I took pictures of the electric-wiring diagram book. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-12-2006, 04:40 PM
Post: #228
Banpeis project
Not only have I switched the server today, I also bought two new shoes for my hachi.
![]() Bought them at http://www.autobandenmarkt.nl/ , just like Ivan did, and to no surprise I bought Falken ZE-512 (195/55 R15, so different size than Ivan) and had them mounted under the hachi. ![]() The tires are a bit softer and comfortable than my previous ones, but those were 195/50 and these are 195/55. I'm really happy about the comfort of the car, but I do have to adjust the shocks to make the car a bit stiffer again. The garage owner was quite pleased to see the car: he owned (according to his stories abused) an ae86 in the past and now owns a Supra MKIII and an Eldorado Fleetwood. They had a bit of trouble balancing the wheel since there was a dent in it (TE71Corolla made it when he owned the car), but when I made pictures today I couldn't believe my eyes how many weights they put on it. ![]() ![]() But it surely helped. Car runs much smoother at 120km/h. ![]() The tires are a bit bigger, but the do tend to disappear a bit behind the fender. So time to find some longer springs or spacers. ![]() Also made some pictures afterwards at a nice spot. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-12-2006, 04:56 PM
Post: #229
Banpeis project
Look good banpei!
![]() I am going to buy new tyres too soon, saving some money now and the tyres will be Falken 512 too ![]() |
06-12-2006, 05:25 PM
Post: #230
Banpeis project
wtf, that's a lot of weight!!
