06-17-2012, 10:02 AM
Post: #121
Bean Bandit Wrote:I know you all prefer pictures ![]() SR Team BURN THE RUBER NOT YOUR SOUL! |
06-17-2012, 04:19 PM
Post: #122
Bean Bandit Wrote:Also some fabrication is needed like a plate to hold the COPsYou can buy that here: http://s-86.com/parts.html He also sell the connectors if you need them ![]() |
06-17-2012, 04:30 PM
Post: #123
Project D Wrote:Bean Bandit Wrote:Also some fabrication is needed like a plate to hold the COPsYou can buy that here: cheaper if I make it myself and to my own taste ![]() The connectors are already ordered though ![]() AE86 ex-daily |
07-17-2012, 11:53 AM
Post: #124
I'm getting the X-Mas feeling already
![]() this is to be posted soon and will hopefully arrive next week: ![]() doesn't include any Honda parts but 26kg (58lb) of 4AGE goodness ![]() custom pistons and rods, spare crank and valve covers, new water pump and more also already received my COP connectors, rebuildable filter and new Project-Levin ![]() ![]() ![]() ![]() AE86 ex-daily |
07-17-2012, 12:08 PM
Post: #125
Bean Bandit Wrote:meanwhile part of the pipe that joins the two water necks felt the urge to disintegrate and hence leak but replcment is underway and all should be good before the end of this month. following up the above problem - I forgot to post the fact Toyota is still awesome and here's why: ![]() click it to get the huge version in all it's glory. This used to be made out of super thin steel that will corrode after years of use and they made a new version despite the fact are cars are out of production (this piece is solely used on 4AGE). ![]() AE86 ex-daily |
07-17-2012, 06:04 PM
Post: #126
Bean Bandit Wrote:(this piece is solely used on 4AGE). I may be mistaken.... but I believe it is only used in rwd 4AGE applications... making it rarer still ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-17-2012, 06:21 PM
Post: #127
oldeskewltoy Wrote:Bean Bandit Wrote:(this piece is solely used on 4AGE). I think you are right ![]() AE86 ex-daily |
07-30-2012, 08:02 AM
Post: #128
BOOMEX Wrote:Bean Bandit Wrote:I know you all prefer pictures So as promised here some pictures or just a teaser as for the first time ever in almost 2 years I'm living in this country it's raining for more than 15min (5hours and counting so far) - so I'm going for a drive to capture the mayhem on the streets ![]() ![]() more to follow once I'm back AE86 ex-daily |
07-30-2012, 04:56 PM
Post: #129
The rain stopped as soon as I got in the car non the less I went for a quick ride. I suck at video editing so I only uploaded one scene.
And yes I had and did clean my car after this trip brace yourself and back to pictures ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() and here a better side by side picture of the water bypass (old->new) ![]() ![]() there's more but not today - build will start after Ramadan ends and the machine shop is able to do precision work again ![]() AE86 ex-daily |
07-30-2012, 07:53 PM
Post: #130
Bean Bandit Wrote: ![]() ![]() DETAILS - static CR? Valve reliefs for stock valves? Is this a custom piston, or to your specifications? Got a piston job # to share so we can order similar pistons?? ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
