06-09-2016, 09:18 PM
(This post was last modified: 06-09-2016 09:31 PM by Bean.)
Post: #381
(06-09-2016 05:57 PM)d3nso Wrote: Can you measure the cutout for the water and oil gauge? I might have a digital gauge to replace these to The opening is 79.7mm wide and 15.7mm high. I reckon, if needed, you could enlarge the opening slightly and extra 5mm in height and width if necessary (see picture below). For bigger version click the picture. EDIT: I also replaced the picture in Post #376 with a slightly better one (still a phone pic). AE86 ex-daily |
06-10-2016, 10:39 AM
Post: #382
So a utcomp-pro 3.2" display would almost fit perfect as it is 79mm x 21mm
Thanks for the info Daily Beater: Civic EG5 Work in progress Car: AE86 |
06-10-2016, 01:23 PM
(This post was last modified: 06-10-2016 01:25 PM by Bean.)
Post: #383
(06-10-2016 10:39 AM)d3nso Wrote: So a utcomp-pro 3.2" display would almost fit perfect as it is 79mm x 21mmyep that should work. It'll go almost to the edge of the zero and the tip of the water sign but will fit. Just lookked that one up. If you mount it similar to oringinal under the bezel you could get away with 19mm hight too If you cut into the water sign I guess you could fit it flush with the top layer of the fascia and have a mm or two spare underneath the zero. AE86 ex-daily |
04-13-2017, 01:53 PM
(This post was last modified: 04-13-2017 01:54 PM by Bean.)
Post: #384
Self explanatory in a few minutes
AE86 ex-daily |
04-13-2017, 04:19 PM
Post: #385
AE86 ex-daily |
04-13-2017, 04:47 PM
Post: #386
busy boy.........
Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-13-2017, 09:40 PM
Post: #387
It took forever, but now I'm on a deadline so have to rush a few things. It won't be finished but it'll look like a car again
AE86 ex-daily |
05-08-2017, 06:11 PM
Post: #388
ready for shipping, tomorrow a transporter will pick her up and she will disapear in a container for 2 months.
picture will follow shortly AE86 ex-daily |
05-08-2017, 08:14 PM
Post: #389
Here we go
AE86 ex-daily |
05-08-2017, 08:28 PM
Post: #390
Bean Bandits Levin 'Globetrotter' | |||
User(s) browsing this thread: 42 Guest(s)
