Big brakes on my SE-86 at last.
09-13-2005, 02:07 PM
Yes Bill, but my goal is to use 14" Supra rims.
Original AE86 rears are 231mm. The 257mm seems to be a little improvement but if we compare the friction surfaces - things are not linear. PS: AFAIK Toyota Corolla Verso 2002+ 1.8 uses ~300mm 4X100mm fronts. But I forgot to measure rear ones ![]() |
09-13-2005, 04:07 PM
Thanks for that. I don't have a vacuum booster any more so I need a large diameter to help the pedal pressures.
What it likely to happen is that I'll find a disc that doesn't have a 'hat' in the middle and we'll just mill one up out of alloy to suit. I'd also like to try to keep the standard caliper, so I can keep the regular handbrake as well. But I guess better pads will be needed, too. |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,130 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 614,438 |
AE86 N2 (big update) | 86Pilot | 110 | 138,868 |
09-06-2013 11:33 AM Last Post: Apsogos |
Brakes kill engine. | Super Snake | 3 | 4,781 |
04-27-2013 01:43 AM Last Post: Super Snake |
Brakes | ae86rebuild | 10 | 11,509 |
11-28-2009 01:38 AM Last Post: mc68 |
